FDCFRANK
#1 Posted : Sunday, April 27, 2025 8:30:50 PM(UTC)
FDCFRANK
Spain
Hi there!.
I´ve been trying to work with an Aja IOX3 Interface on VMix without success, trying to manage simulateusly 4 in/out audio (One IOX3 mode). I wrote to Aja Tech department and here their response:
"Unfortunately, when vMix is using the IoX3, it ignores the Control Panel settings. vMix configures the DB-25 connector as input only and there is no way that I am aware of to change this".
Could be very nice to add compatibility in futures VMix updates to take full Aja´s audio advantages...
sinc747
#2 Posted : Saturday, May 3, 2025 1:34:02 AM(UTC)
sinc747
Suggest you contact vMix tech support on this issue. When vMix made its own hardware the AJA cards were the standard offering. I bet they have a lot of expertise in getting the AJA cards corrected configured.
- Tom
FDCFRANK on 5/3/2025(UTC)
FDCFRANK
#3 Posted : Saturday, May 3, 2025 3:17:32 AM(UTC)
FDCFRANK
Spain
Hi Tom, thank you so much for your reply. I wrote to AJA tech support and they responded:
So, in this case Vmix is not audio compatible with IOX3 via Dsub25 connector in 4in/4out mode.
Best regards
Similar Topics
NDI Source for OSX Now Available - SDI/HDMI to NDI with BMD or AJA interfaces (NDI)
by livepad 4/9/2016 5:17:18 PM(UTC)
