knbPixels
#1 Posted : Friday, May 2, 2025 11:30:11 AM(UTC)
knbPixels
I am unable to get either the Set Stinger or SetStingerGTInput shortcuts to work.
When I invoke the Set Stinger button, it just plays the chosen input in the program window, but not as a stinger, and if I then go to the Overlays Settings panel and look at that stinger, source is still set to None.
Seperately, when I try the GTInput shortcut instead, nothing happens. My Stinger slot is still set to None. Having a way to swap inputs on a stinger with a shortcut would be of large benefit for our workflow
Ben-vMix
#2 Posted : Friday, May 2, 2025 3:06:41 PM(UTC)
Ben-vMix
Rank: Staff
Groups: Registered, Moderator
Hi there,
When setting up the "SetStingerGTInput1" shortcut. Can you please check what you are setting as "Input"? This should be one of the built-in GT Stingers in vMix or one of your own. When selected, this shortcut should set Stinger 1 in vMix appropriately.
If you have any further issues, please send through an email to support@vmix.com or contact us via our contact form below:
https://www.vmix.com/contact-us.aspx
knbPixels
#3 Posted : Friday, May 2, 2025 9:04:38 PM(UTC)
knbPixels
Originally Posted by: Ben-vMix Go to Quoted Post
Hi there,
Yes, I dropped a GTzip file into vMix as an input and had selected that as the Input to use on SetStingerGTInput. As I said, the shortcut didn't work because Overlay Settings still showed None as the stinger source. I will email in.
knbPixels
#4 Posted : Friday, May 2, 2025 11:29:22 PM(UTC)
knbPixels
After talking with support, what I'm trying to do is not a feature currently. Feature request posted.
