"Set Stinger" Shortcuts not working
Joined: 2/7/2024(UTC) Posts: 197  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
I am unable to get either the Set Stinger or SetStingerGTInput shortcuts to work.
When I invoke the Set Stinger button, it just plays the chosen input in the program window, but not as a stinger, and if I then go to the Overlays Settings panel and look at that stinger, source is still set to None.
Seperately, when I try the GTInput shortcut instead, nothing happens. My Stinger slot is still set to None. Having a way to swap inputs on a stinger with a shortcut would be of large benefit for our workflow
Rank: Staff
Groups: Registered, Moderator Joined: 2/13/2023(UTC) Posts: 8  Location: Queensland
Hi there, When setting up the "SetStingerGTInput1" shortcut. Can you please check what you are setting as "Input"? This should be one of the built-in GT Stingers in vMix or one of your own. When selected, this shortcut should set Stinger 1 in vMix appropriately. If you have any further issues, please send through an email to support@vmix.com or contact us via our contact form below: https://www.vmix.com/contact-us.aspx
Originally Posted by: Ben-vMix  Hi there, When setting up the "SetStingerGTInput1" shortcut. Can you please check what you are setting as "Input"? This should be one of the built-in GT Stingers in vMix or one of your own. When selected, this shortcut should set Stinger 1 in vMix appropriately. If you have any further issues, please send through an email to support@vmix.com or contact us via our contact form below: https://www.vmix.com/contact-us.aspx Yes, I dropped a GTzip file into vMix as an input and had selected that as the Input to use on SetStingerGTInput. As I said, the shortcut didn't work because Overlay Settings still showed None as the stinger source. I will email in.
After talking with support, what I'm trying to do is not a feature currently. Feature request posted.
