AlToms
#1 Posted : Friday, May 20, 2022 4:43:18 AM(UTC)
AlToms
Canada
In our typical workflow, we record in camera, record each live source in vMix Multicorder, and record our Program Output.
I've noticed that the colour in the Multicorder file has different colour than the Program Output file, even on a straight 1:1 of the source. In this very simple example you can see that ISO record is more magenta than the Program Output. These differences are accentuated in less controllable circumstances.
Any ideas why this would be happening? It adds a very unnecessary step in our post-production workflow when cleaning up a live-edit.
Multicorder:
Program Output:
Backstage Program Rec.png (2,175kb) downloaded 15 time(s).
Computer Specs:
Windows 10 Pro
Asus ROG Maximus Z690 Hero
Intel i9-12900K
32GB RAM
MSI Ventus 3x Plus RTX 3080
BMD Decklink Quad HDMI Recorder
#2 Posted : Saturday, May 21, 2022 10:03:47 AM(UTC)
@ AlToms
The vMix MultiCorder records the raw camera source.
The vMix Recorder records the processed video through vMix, so even though you may not have adjusted anything, that processing in and of itself may be "auto tweaking" things to some degree.
AlToms on 5/25/2022(UTC)
AlToms
#3 Posted : Wednesday, May 25, 2022 3:14:27 AM(UTC)
AlToms
Canada
That's what I suspected, thanks very much for confirming I'm not losing my mind.
Is there any way of either:
1) Removing the "auto tweaking"
or
2) Adjusting the multicorder to match the processing happening to the Program Rec?
My work is usually focused on live-editing events and turning around a final, corrections-included and repackaged, video(s) within a week or less. Adjusting for these differences seems to be a bit of an extra bother for not apparent benefit.
nikosman88
#4 Posted : Sunday, June 26, 2022 7:17:15 PM(UTC)
nikosman88
Greece
Hello. Did you find any solution for this? I noticed that this happens only in specific cameras. I have a sony ax53 connected to a bmd mini recorder and a panasonic vc-180 connected in another bmd mini recorder. The sony camera doesnt have this magenta colour in multicorder record and it is exactly same like the pgm output. But the panasonic camera does have this more magenta colour only in multicorder
AlToms
#5 Posted : Tuesday, June 28, 2022 12:45:59 AM(UTC)
AlToms
Canada
I have not yet unfortunately. Interesting to hear about only affecting specific cameras though....means there's hope that there's a setting somewhere I can alter. I wonder if the HDMI out image profile can be tweaked to compensate.
dexxer
#6 Posted : Friday, April 18, 2025 7:42:56 AM(UTC)
dexxer
Canada
I'm having the same problem.
The vMix recording have a magenta cast, that makes skin tone a bit wonky at times.
I tried recording in an ATEM mini in parallel, color in the ATEM program fine.
Colours from vMix have an annoying magenta cast.
Did someone found a solution to this?
Luis70
#7 Posted : Friday, April 18, 2025 10:20:24 AM(UTC)
Luis70
Grenada
Was thanked: 11 time(s) in 11 post(s)
I found that, and what I do, is to use the colour correction in the 'output' to match the input, as it is the output that has the processing. ... what I do, as I noticed that the whites are kinda washed out a bit, is to adjust the "gamma', the "lift", and keep tweeking of the other colour adjustments until I am satisfied with the output.
