knbPixels
#1 Posted : Friday, April 18, 2025 7:11:09 AM(UTC)
knbPixels
This has happened to me several times in the past. When I disconnect vMix from Zoom, at times my all of my USB devices flash off for a few seconds, and then back on. Almost all of my USB devices are plugged into wall powered hubs and not using PC USB bus power.
Today when I disconnected vMix from Zoom all USB devices turned off completely and stayed off. I had to do a hard reboot twice to get USB power back to the devices. I tried different USB ports during the error state, even plugging in a keyboard directly to the PC, and none of them worked.
About 2 weeks ago I followed the guide in the vMix documentation to turn off power saving features for the USB bus devices in Device Manager.
I'm at a loss as to what is causing this, and why it ONLY happens (though not every time) when I disconnect vMix from Zoom.
knbPixels
#2 Posted : Friday, April 18, 2025 7:27:23 AM(UTC)
knbPixels
I found the error reports related to the USB controller. I'll post an image of the errors that happened, and then the text of each error in order:
image (16).png (328kb) downloaded 48 time(s).
USBXHCI Controller Error Encountered
Device Instance ID: PCI\VEN_8086&DEV_7A60&SUBSYS_7A601849&REV_11\3&11583659&0&A0
Failure Reason: Set dequeue pointer failed during an attempt to set the dequeue pointer after endpoint stop completion.
Recovery Action: Reset
Bus Type: ParentBusTypePci
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
PCI Vendor ID: 0x8086
PCI Device ID: 0x7A60
PCI Revision ID: 0x11
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Firmware Version: 0xFFFFFFFFFFFFFFFF
Instance Number: 0x0
Failure Parameter 3: 0x0
Failure Parameter 4: 0x0
Failure Reason: An xHCI controller command failed to complete after the command timeout abort.
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
Just checked my USB controller driver and it is listed as up to date and was updated 3/25/25, though this issue has been going on for 6 months. My bios was already updated as of a month ago. I just discovered the option for turning off USB Selective Suspend in Power Options. We will see what happens
knbPixels
#3 Posted : Tuesday, April 29, 2025 11:14:00 PM(UTC)
knbPixels
Have not seen this issue happen again since I hit the option for turning off USB Selective Suspend in Power Options. Will update down the road.
knbPixels
#4 Posted : Wednesday, May 7, 2025 6:22:27 AM(UTC)
knbPixels
Just saw this issue happen again, only this time it was a little different. Instead of the choise to disconnect from Zoom in vMix causing the USB failure, it happened when I ended the meeting. All USB devices went dark, and I had to hard restart.
knbPixels
#5 Posted : Tuesday, May 20, 2025 2:14:01 AM(UTC)
knbPixels
Error happened again today, Failure reason is different message than before:
Log Name: Microsoft-Windows-USB-USBXHCI-Operational
Source: Microsoft-Windows-USB-USBXHCI
Date: 5/19/2025 11:09:35 AM
Event ID: 50
Task Category: USBXHCI Controller Error Encountered
Level: Error
Keywords: (1)
User: N/A
Description:
Major Version: 0x1
Minor Version: 0x20
PCI b.d.f: 0.20.0
ACPI Vendor ID:
ACPI Device ID:
ACPI Revision ID:
