fgolman
#1 Posted : Thursday, April 10, 2025 9:45:58 AM(UTC)
fgolman
Please clarify that the API documentation regarding sheet names isn't functional, even though it appears that one should be able to script to pick up data from multiple sheets from a single file.
The data source manager does expose it. Just not through application of scripting via the API.
Driving me crazy.
Yes, I can create a much larger single spreadsheet with groupings of information, but the sheet name mechanism yields much cleaner code.
Thanks,
Fritz Golman
RadioDNA
#2 Posted : Thursday, April 10, 2025 11:48:21 AM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
That is not accurate, the API and the shortcuts for data sources work as described, so you are going to need to provide some examples.
fgolman
#3 Posted : Thursday, April 10, 2025 12:34:04 PM(UTC)
fgolman
OK here are the details, as a demonstration.
Simple Excel spreadsheet with these tabs:
Sheet1:
cam1-a desc1-a
cam2-a desc2-a
cam3-a desc3-a
Sheet2:
cam1-b desc1-b
cam2-b desc2-b
cam3-b desc3-b
No matter what I do this API call won't get data from Sheet2.
api.function("DataSourceSelectRow",,"Excel/CSV,Sheet2,0") which should pull up cam1-b, desc1-b or
api.function("DataSourceSelectRow",,"Excel/CSV,Sheet2,1") which should pull up cam2-b, desc2-b or
api.function("DataSourceSelectRow",,"Excel/CSV,Sheet2,2") which should pull up cam3-b, desc3-b.
However, it will pull up from Sheet1 as appropriate, using this API calls like this: api.function("DataSourceSelectRow",,"Excel/CSV,Sheet1,1")
Is it something in how this is mapped in the Data Source Manager? It does see Sheet1 and Sheet2 in the dropdown, so it's definitely pulling up the spreadsheet correctly.
Now, if I'm doing something wrong, let me know.
Also, a clarification, this feeds into a lower third with name (which is example for cam1, 2, 3) and additional text description (which is example with desc1, 2, 3). I can see it changing when using Sheet1 but not Sheet2.
Thank you,
Fritz Golman
RadioDNA
#4 Posted : Thursday, April 10, 2025 7:07:59 PM(UTC)
I just did a quick test with a 2 sheet spreadsheet and the scripting functions work as expected.
Double check the spelling to ensure the sheet names entered exactly match what they are called in the spreadsheet.
Failing that you can contact vMix Support (https://www.vmix.com/contact-us.aspx)
(Use the Email address at the bottom of the page so you can add attachments)
Attach the spreadsheets and presets used and we should be able to see where the issue is.
fgolman
#5 Posted : Thursday, April 10, 2025 8:55:47 PM(UTC)
fgolman
It's literally copy and paste from example above.
I'll drop support a note.
#6 Posted : Thursday, April 10, 2025 11:55:05 PM(UTC)
So I have just re-read your example, and is it possible that maybe you have misunderstood what DataSourceSelectRow is for?
Its purpose is to change the selected row within a particular table/sheet. It won't change the table/sheet assigned to a title field to something else...
For example, say you have two titles, one assigned to Sheet1 and one assigned to Sheet2.
These shortcuts can independently switch which row each of the titles is assigned to. (assuming the data mapping row in a title is set to "Selected")
Hope this clears things up.
eduardocfs on 4/15/2025(UTC)
fgolman
#7 Posted : Friday, April 11, 2025 12:42:13 AM(UTC)
fgolman
OK I think this gets to the bottom of the issue.
Certainly wasn't clear that it only operates within one sub-sheet/tab of the entire spreadsheet.
Thanks for the clarification.
Now I'll just have to build the spreadsheet with blocks of titles stacked in fixed groupings. Not as clean both in code and in the spreadsheet itself but that's ok.
Thanks again.
Fritz Golman
RadioDNA
vighneshacharya
#8 Posted : Thursday, April 17, 2025 4:49:20 AM(UTC)
vighneshacharya
India
Hi i have some doubt in Data source anyone please help me.
In vmix Data source when i click first row as data name and convert to row to column that data row name should show "heading1" , heading2 so on but in my case its coming . (Dot) In between like heading.1 heading.2
Can i know the reason?
#9 Posted : Thursday, April 17, 2025 5:35:03 AM(UTC)
Because thats how it is (now). Depends on the type of source used , this behavior is by design to avoid conflict with naming (according to vMix).
https://forums.vmix.com/...ows-to-columns#post75717
Guest (5)
