I have never really had problems livestreaming with vMix untill the past couple of weeks. I run a church livestream and we use Facebook and a thirdparty sermon site to host our streams. Very recently, the streams will dip framerates to like 1 every 2 or 3 seconds and choppy audio for 20-30 seconds. Then it returns to the normal speed. I'm not the most tech savvy guy in the world and I was wondering if anyone had ideas on what might be casuing this issue.
Thanks in advance.
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
Does the red stream button in vMix start flashing yellow when this happens?
Are you streaming directly to Facebook, or are you streaming to a 3rd party site like restream.io, which then restreams it to facebook?
Joined: 3/28/2025(UTC) Posts: 1  Location: United States
Do you stream to Facebook directly, or do you stream to a third-party website like restream.io, which restreams it to Facebook?
Joined: 6/19/2020(UTC) Posts: 9  Location: Oakton Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
My problem may be similar. I'm streaming directly to Facebook live. I'm not sure I'd call it "choppy" but FB does report a drop in the quality (red on the video stream graphic). The vmix "Stream" indicator will flash yellow.
I have a solid, hardwired, FIOS internet connection, so it's not that.
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
It can be so many things. Try to trace-route the facebook server to see where the issue might be. For a more constant monitoring you can download WinMTR. A change in DNS server might also change the route or provide a better entry point. RTMP is unfortunately a very old protocol with no resiliance build in. If you find a service that supports SRT entry you might having less issues.
Originally Posted by: kross  Does the red stream button in vMix start flashing yellow when this happens?
Are you streaming directly to Facebook, or are you streaming to a 3rd party site like restream.io, which then restreams it to facebook? Yes that's what happens. And I'm streaming directly.
