Faithfuldog
#1 Posted : Thursday, March 27, 2025 10:21:42 AM(UTC)
Faithfuldog
I have never really had problems livestreaming with vMix untill the past couple of weeks. I run a church livestream and we use Facebook and a thirdparty sermon site to host our streams. Very recently, the streams will dip framerates to like 1 every 2 or 3 seconds and choppy audio for 20-30 seconds. Then it returns to the normal speed. I'm not the most tech savvy guy in the world and I was wondering if anyone had ideas on what might be casuing this issue.
Thanks in advance.
kross
#2 Posted : Friday, March 28, 2025 10:53:28 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
Does the red stream button in vMix start flashing yellow when this happens?
Are you streaming directly to Facebook, or are you streaming to a 3rd party site like restream.io, which then restreams it to facebook?
farawayoptimal
#3 Posted : Friday, March 28, 2025 12:09:20 PM(UTC)
farawayoptimal
American Samoa
Do you stream to Facebook directly, or do you stream to a third-party website like restream.io, which restreams it to Facebook?
JefHaugh
#4 Posted : Saturday, March 29, 2025 12:19:35 AM(UTC)
JefHaugh
My problem may be similar. I'm streaming directly to Facebook live. I'm not sure I'd call it "choppy" but FB does report a drop in the quality (red on the video stream graphic). The vmix "Stream" indicator will flash yellow.
I have a solid, hardwired, FIOS internet connection, so it's not that.
mavik
#5 Posted : Saturday, March 29, 2025 10:37:01 PM(UTC)
mavik
It can be so many things. Try to trace-route the facebook server to see where the issue might be. For a more constant monitoring you can download WinMTR. A change in DNS server might also change the route or provide a better entry point.
RTMP is unfortunately a very old protocol with no resiliance build in. If you find a service that supports SRT entry you might having less issues.
Faithfuldog
#6 Posted : Thursday, April 3, 2025 9:27:26 AM(UTC)
Faithfuldog
Yes that's what happens. And I'm streaming directly.
