Systems
Referece system for 20 NDI PTZ Cameras 2K @ 60 FPS
Hello everyone, I am building a large NDI video capture solution for research. The application is to capture 20 cameras 2k @ 60 fps (main application is soccer/football capture). We want to record all of the video to disk. There is no real need for realtime or compression on the fly etc. Really I just need to aim the PTZ cameras and start/stop record. Also, the cameras need to be synced. I am possibly trying to stick with NDI vs. having a system that requires Time Code. Is it possible to build a System that can handle 20 cameras? I have seen the https://www.vmix.com/pro...ce-systems.aspx#obtanium and I understand the cost/complexity - we should have budget. Or would it be more advisable to link several Systems together? Does this make Sync difficult? Does anyone have any experience with this? Does it sound doable or terrifying? Regards, Alex ** I am new here so super sorry if I have posted a newbie question or in the wrong place.
Originally Posted by: Bulldog  Hello everyone, I am building a large NDI video capture solution for research. The application is to capture 20 cameras 2k @ 60 fps (main application is soccer/football capture). We want to record all of the video to disk. There is no real need for realtime or compression on the fly etc. Really I just need to aim the PTZ cameras and start/stop record. Also, the cameras need to be synced. I am possibly trying to stick with NDI vs. having a system that requires Time Code. Is it possible to build a System that can handle 20 cameras? I have seen the https://www.vmix.com/pro...ce-systems.aspx#obtanium and I understand the cost/complexity - we should have budget. Or would it be more advisable to link several Systems together? Does this make Sync difficult? Does anyone have any experience with this? Does it sound doable or terrifying? Regards, Alex ** I am new here so super sorry if I have posted a newbie question or in the wrong place. It should be on two Obtainium computers. 10 cameras each. But I still see it as being tight and pushing the limit. Especially for the sustained recording speed of the SSD. Then the other problem is that vMix still doesn't accept external time codes. From what I understand.
Thank you for the reply!
I will have to look into the TC solution. Maybe using NTP?
Systems
