ihtus
#1 Posted : Monday, August 25, 2014 10:12:33 PM(UTC)
ihtus
vMix is a great and unique software, thank you developers, God bless you and God bless Australia !!!
I am not sure this is the right category.
Here is my question.
I am adding a new input - a video file which has the size of 672px x 256px
vMix is set to 1280 x 720 for output size, and output aspect ratio - widescreen.
So when I add the video, the real image size is distorted to 1280 x 542.
If vMix would keep the aspect ratio of the video, the new video size would be 1280 x 488
But I cannot set a custom aspect ratio and vMix is making the video bigger in height: should be 1280 x 488, but it makes it 1280 x 542
I saw a post how to keep the aspect ration of the static image: by using 'photos' when adding input, instead of 'image'.
Also I am aware that there is an option to go to 'position' and change the zoom to make the video to look as wanted.
I tried to use zoom, but it is really hard to make the video to have exactly same aspect ratio as in original video.
I don't know what values are displayed there while changing the zoom.
Does my issue have a better workaround than I already listed here?
Or there is no solution and this could be considered as a feature request?
#2 Posted : Monday, August 25, 2014 10:24:36 PM(UTC)
@ ihtus
Have you tried all "Aspect Ratio" options in the pull down menu?
In particular, what happens when you choose "Source" or "Anamorphic"?
ihtus
#3 Posted : Tuesday, August 26, 2014 2:05:38 AM(UTC)
ihtus
@IceStream,
thank you for your reply.
Here is what I get for the various available aspect ratio options:
1280 x 720 - Output Size (vMix -> Settings -> Display)
672 x 256 - original size of input video
1280 x 488 - expected non-distorted size.
But this size I get when importing to vMiX:
normal => 1280 x 364 (height smaller than needed)
widescreen => 1280 x 542 (height bigger than needed)
anamorphic => 1280 x 542 (height bigger than needed)
Original size of input video
Aspect ratio in vMix:
normal:
wide:
anamorphic:
Damn2Good4U
#4 Posted : Tuesday, August 26, 2014 8:34:21 AM(UTC)
Damn2Good4U
Hi ihtus,
Try to put this figure in the zoom if it will solve your problem 1.34 and remember to leave the video aspect ratio to "source"
ihtus
#5 Posted : Tuesday, August 26, 2014 9:32:40 AM(UTC)
ihtus
@Damn2Good4U
thanks. With the most updated vMix I don't see "source" aspect ratio.. there is normal, widescreen and anamorphic only.
Do you mean "normal"?
Zoom is a workaround, but that would be great if I could see pixels instead of weird numbers while I am changing zoom or position...
If I would see pixel values I would be able to adjust perfectly and accurately the image to original aspect ratio.
Is there any way to see pixel values there?
Damn2Good4U
#6 Posted : Tuesday, August 26, 2014 12:50:08 PM(UTC)
Damn2Good4U
I have just rechecked vMix v14.0.0.57 and the source is there with the normal, widescreen and anamorphic
ihtus
#7 Posted : Tuesday, August 26, 2014 2:53:34 PM(UTC)
ihtus
wow... i downloaded several days ago and the version was 13.xxx
Is 14.xx available for public download?
p.s. i am at work and cannot download and install right away, will do that at home.
ihtus
#8 Posted : Tuesday, August 26, 2014 3:06:12 PM(UTC)
ihtus
The last version available for download is 13.0.0.142
Where can I download version 14?
ovinas
#9 Posted : Tuesday, August 26, 2014 3:25:27 PM(UTC)
ovinas
Damn2Good4U
#10 Posted : Tuesday, August 26, 2014 5:56:16 PM(UTC)
Damn2Good4U
I currently use 13 as my production version... v14 is still in a beta version... but at that. my v13 has the source.. maybe you have some missing files while installing vMix... please check
ihtus
#11 Posted: : Tuesday, August 26, 2014 9:49:33 PM(UTC)
ihtus
very weird...
just fully uninstalled 13 and installed 14.0.0.57 (x64) and only have normal, widescreen and anamorphic.
No 'source'...
I don't know why is that... any ideas?
ihtus
#12 Posted : Tuesday, August 26, 2014 10:18:45 PM(UTC)
ihtus
Now I found it... it is in the input setting, and yes I have source aspect ratio.
I combined all values of aspect ratio (source, normal, widescreen, anamorphic) from input settings with all values of aspect ratio (normal, widescreen, anamorphic) from general settings, but with no luck, in all combinations the image is distorted and is not kept in original aspect ratio :(
#13 Posted : Wednesday, August 27, 2014 12:27:10 AM(UTC)
I am not all that familiar with anamorphic aspect ratio inputs in vMix or why your video is resized the way it is, other than maybe there is some sort of over scan dimensions it is detecting in the video.
Perhaps Martin can chime in as to how vMix handles or conforms different sized inputs.
In any event, I suspect using "source" should give you the closest proximity to the original and playing with the Y zoom slider might give you a little less vertical stretch if that is what you are after.
If you don't mind my asking, what video format is your video file? Is it purely anamorphic?
ihtus
#14 Posted : Wednesday, August 27, 2014 11:27:00 AM(UTC)
ihtus
The specific video I brought here is avi (mpeg4, xvid) 672 x 256.
But the distortion happens to any avi video I add.
Yes, you are right, source aspect ratio is the closest to original, but it is still distorted.
I don't mind to adjust zoom if I would see dynamically changed values in PX, instead I see there some strange decimal values.
If I would see PC in zoom => I would able to accurately adjust the size.
Martin, could you please consider to display PX while zooming?
ihtus
#15 Posted : Wednesday, August 27, 2014 7:11:08 PM(UTC)
ihtus
thanks to Jesus, there is a workaround that helped me to achieve accurate and wanted results.
If anyone need, I am sharing it with others. Hope that helps anybody.
1. Let's say your project size is 1280 x 720 (in settings, aspect ratio: widescreen)
2. Let's say your video size is 672 x 256 (in input settings, aspect ratio: source)
3. Calculate what would be video height if width stretched to 1280px width:
672 x 256
1280 x Z
Z=(1280*256)/672 ~ 488 px
So my new video size (for 1280 x 720 format) would be 1280 x 488
4. Make an PNG image 1280 x 720 with 1280 x 488 cropped in the middle, see pic below
5. Add your video to vMix input 1
6. Add your image to vMix input 2
7. overlay input with image over input with video
8. Click on Fullscreen (this is to have more accurate results)
9. Go to Video Input 1 settings
10. Go to Position and play with "Zoom Y". Adjust it with mouse and then with keyboard for more accuracy. On the fullscreen (in the background) you will see the effects right away. Adjust the video "Zoom Y" so top and bottom edges will reach red edges of the image.
#16 Posted : Wednesday, August 27, 2014 11:25:32 PM(UTC)
@ ihtus
Out of curiosity, what is the final value of the Y Zoom?
This will likely be consistent through all your videos, just as 1.345 is the zoom factor for 4:3 to 16:9.
ihtus
#17 Posted : Friday, August 29, 2014 1:15:08 AM(UTC)
ihtus
@IceStream
1) 672 x 256 video for 1280 x 720 vMix project size: Y Zoom = 0.904
2) 704 x 368 video for 1280 x 720 vMix project size: Y Zoom = 0.9315
The y-zoom would be the same if I would have same video size for all videos.
800 x 600 => 4/3 = 1.(3) asp ratio
672 x 256 => 2.625 asp ratio
704 x 368 => 1.913 asp ratio
So we have here 3 different aspect ratios => will have different y-zoom values.
Guest (9)
