Kapelaan
#1 Posted : Friday, March 14, 2025 5:18:09 PM(UTC)
Kapelaan
South Africa
Hey everyone,
I’ve set up a vMix preset for sports streaming, and I’m using a squeeze-back ad space where images rotate automatically. Right now, I have it set to select the next image on OnTransitionOut, and it works perfectly.
However, I can’t figure out the right trigger to restart the image sequence once the last image has been displayed. Right now, it just stops at the last image instead of looping back to the first one.
Has anyone dealt with this before? Any advice on the correct trigger or workaround to make it loop continuously?
Thanks in advance!
#2 Posted : Friday, March 14, 2025 6:31:06 PM(UTC)
Originally Posted by: Kapelaan Go to Quoted Post
Hey everyone,
Thanks in advance!
Are you using "List" input for your imqges (failed to mention)? There is a "loop" option there,
Using photos one can loop the input
fyi there are better FB groups to also ask this there ;-)
Kapelaan
#3 Posted : Friday, March 14, 2025 6:47:32 PM(UTC)
Kapelaan
South Africa
I apologise for not mentioning. I'm using a photos input. I will try list input.
#4 Posted : Friday, March 14, 2025 7:13:40 PM(UTC)
Photos? then as mentioned activate the loop of the input (most inputs have it )
Kapelaan
#5 Posted : Friday, March 14, 2025 7:17:15 PM(UTC)
Kapelaan
South Africa
photo_2025-03-14_11-20-24.jpg (191kb) downloaded 2 time(s).Problem solved. Thanks. Activated loop button under the input. Now it loops around. Thank you.
