I need help with a trigger please.
Hey everyone,
I’ve set up a vMix preset for sports streaming, and I’m using a squeeze-back ad space where images rotate automatically. Right now, I have it set to select the next image on OnTransitionOut, and it works perfectly.
However, I can’t figure out the right trigger to restart the image sequence once the last image has been displayed. Right now, it just stops at the last image instead of looping back to the first one.
Has anyone dealt with this before? Any advice on the correct trigger or workaround to make it loop continuously?
Thanks in advance!
Thanks in advance! Are you using "List" input for your imqges (failed to mention)? There is a "loop" option there, Using photos one can loop the input fyi there are better FB groups to also ask this there ;-)
I apologise for not mentioning. I'm using a photos input. I will try list input.
Originally Posted by: Kapelaan  I apologise for not mentioning. I'm using a photos input. I will try list input. Photos? then as mentioned activate the loop of the input (most inputs have it )
 photo_2025-03-14_11-20-24.jpg (191kb) downloaded 2 time(s).Problem solved. Thanks. Activated loop button under the input. Now it loops around. Thank you.
