Hardware Compatibility
DekTec cards compatible with vMixsoftware
Joined: 3/5/2025(UTC) Posts: 3  Location: Denver Was thanked: 1 time(s) in 1 post(s)
Vmix has successfully validated multiple DekTec cards, guaranteeing seamless compatibility with minimal to zero frame drops per hour. • DTA-2178 – 8x12G-SDI/ASI Ports for PCIe • DTA-2174B – 4x 3G-SDI/ASI Ports, 1x12G for PCIe • DTA-2172 – 2x Dual 3G-SDI/ASI Ports for PCIe • DTU-351 – HD-SDI Input for USB-3 product details located at: https://www.dektec.com/selector/asisdi/Designed for 24/7 broadcast, these DekTec products are optimized for vMix software delivering high performance at a competitive price. DirectShow filters and drivers for DekTec hardware can be found at: https://www.dektec.com/downloads/SDK/#winsdkIf you need help with using DekTec card with VMIX software contact DekTec at info@dektec.com
 1 user thanked DekTec America for this useful post.
Hi. Is in your business plan to make a product in terms of price and specs "against" the decklink mini recorder/monitor series models pci-e 1x?
Hello. We don't have a plan right now to have a single card for that low if a price. the lowest price for SDI I/O we have now is DTA-2172: 2x 3G-SDI/ASI ports in or out, low profile PCIe (standard-profile bracket mounted) for 576 USD. I will pass the requirement to the design team. Thanks for the feedback!
Joined: 12/10/2024(UTC) Posts: 1  Location: Westminster
DekTec DTA-2178 8x 12G-SDI/ASI ports, low-profile PCIe was reviewed and featured on the monthly news letter from vMix. Check it out:
Originally Posted by: DekTec America  Vmix has successfully validated multiple DekTec cards, guaranteeing seamless compatibility with minimal to zero frame drops per hour. • DTA-2178 – 8x12G-SDI/ASI Ports for PCIe • DTA-2174B – 4x 3G-SDI/ASI Ports, 1x12G for PCIe • DTA-2172 – 2x Dual 3G-SDI/ASI Ports for PCIe • DTU-351 – HD-SDI Input for USB-3 product details located at: https://www.dektec.com/selector/asisdi/Designed for 24/7 broadcast, these DekTec products are optimized for vMix software delivering high performance at a competitive price. DirectShow filters and drivers for DekTec hardware can be found at: https://www.dektec.com/downloads/SDK/#winsdkIf you need help with using DekTec card with VMIX software contact DekTec at info@dektec.com Hello! I bought DTA-2178, can i use fill/key output though this card?
Originally Posted by: Icerunner  Originally Posted by: DekTec America  Vmix has successfully validated multiple DekTec cards, guaranteeing seamless compatibility with minimal to zero frame drops per hour. • DTA-2178 – 8x12G-SDI/ASI Ports for PCIe • DTA-2174B – 4x 3G-SDI/ASI Ports, 1x12G for PCIe • DTA-2172 – 2x Dual 3G-SDI/ASI Ports for PCIe • DTU-351 – HD-SDI Input for USB-3 product details located at: https://www.dektec.com/selector/asisdi/Designed for 24/7 broadcast, these DekTec products are optimized for vMix software delivering high performance at a competitive price. DirectShow filters and drivers for DekTec hardware can be found at: https://www.dektec.com/downloads/SDK/#winsdkIf you need help with using DekTec card with VMIX software contact DekTec at info@dektec.com Hello! I bought DTA-2178, can i use fill/key output though this card? Hello back! Unfortunatly the DTA-2178 doesnt support fill/key at this time as this software feature has not been implemented.
Thanks: 8 times Was thanked: 11 time(s) in 8 post(s)
How do you get 8x 12G-SDI on a pcie gen3 x8 lane connection?
Isn't that only 8x8Gbit/s?
Joined: 10/20/2023(UTC) Posts: 153  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: Anders  How do you get 8x 12G-SDI on a pcie gen3 x8 lane connection?
Isn't that only 8x8Gbit/s? 8x 12G-SDI input with scaling to 3G-SDI  Capture d'ecran 2026-05-26 15374.png (226kb) downloaded 13 time(s).
 1 user thanked Kayo33 for this useful post.
