Hardware Compatibility
DekTec cards compatible with vMixsoftware
Joined: 3/5/2025(UTC) Posts: 3  Location: Denver Was thanked: 1 time(s) in 1 post(s)
Vmix has successfully validated multiple DekTec cards, guaranteeing seamless compatibility with minimal to zero frame drops per hour. • DTA-2178 – 8x12G-SDI/ASI Ports for PCIe • DTA-2174B – 4x 3G-SDI/ASI Ports, 1x12G for PCIe • DTA-2172 – 2x Dual 3G-SDI/ASI Ports for PCIe • DTU-351 – HD-SDI Input for USB-3 product details located at: https://www.dektec.com/selector/asisdi/Designed for 24/7 broadcast, these DekTec products are optimized for vMix software delivering high performance at a competitive price. DirectShow filters and drivers for DekTec hardware can be found at: https://www.dektec.com/downloads/SDK/#winsdkIf you need help with using DekTec card with VMIX software contact DekTec at info@dektec.com
 1 user thanked DekTec America for this useful post.
Hi. Is in your business plan to make a product in terms of price and specs "against" the decklink mini recorder/monitor series models pci-e 1x?
Hello. We don't have a plan right now to have a single card for that low if a price. the lowest price for SDI I/O we have now is DTA-2172: 2x 3G-SDI/ASI ports in or out, low profile PCIe (standard-profile bracket mounted) for 576 USD. I will pass the requirement to the design team. Thanks for the feedback!
Joined: 12/10/2024(UTC) Posts: 1  Location: Westminster
DekTec DTA-2178 8x 12G-SDI/ASI ports, low-profile PCIe was reviewed and featured on the monthly news letter from vMix. Check it out:
Originally Posted by: DekTec America  Vmix has successfully validated multiple DekTec cards, guaranteeing seamless compatibility with minimal to zero frame drops per hour. • DTA-2178 – 8x12G-SDI/ASI Ports for PCIe • DTA-2174B – 4x 3G-SDI/ASI Ports, 1x12G for PCIe • DTA-2172 – 2x Dual 3G-SDI/ASI Ports for PCIe • DTU-351 – HD-SDI Input for USB-3 product details located at: https://www.dektec.com/selector/asisdi/Designed for 24/7 broadcast, these DekTec products are optimized for vMix software delivering high performance at a competitive price. DirectShow filters and drivers for DekTec hardware can be found at: https://www.dektec.com/downloads/SDK/#winsdkIf you need help with using DekTec card with VMIX software contact DekTec at info@dektec.com Hello! I bought DTA-2178, can i use fill/key output though this card?
Originally Posted by: Icerunner  Originally Posted by: DekTec America  Vmix has successfully validated multiple DekTec cards, guaranteeing seamless compatibility with minimal to zero frame drops per hour. • DTA-2178 – 8x12G-SDI/ASI Ports for PCIe • DTA-2174B – 4x 3G-SDI/ASI Ports, 1x12G for PCIe • DTA-2172 – 2x Dual 3G-SDI/ASI Ports for PCIe • DTU-351 – HD-SDI Input for USB-3 product details located at: https://www.dektec.com/selector/asisdi/Designed for 24/7 broadcast, these DekTec products are optimized for vMix software delivering high performance at a competitive price. DirectShow filters and drivers for DekTec hardware can be found at: https://www.dektec.com/downloads/SDK/#winsdkIf you need help with using DekTec card with VMIX software contact DekTec at info@dektec.com Hello! I bought DTA-2178, can i use fill/key output though this card? Hello back! Unfortunatly the DTA-2178 doesnt support fill/key at this time as this software feature has not been implemented.
Thanks: 8 times Was thanked: 12 time(s) in 9 post(s)
How do you get 8x 12G-SDI on a pcie gen3 x8 lane connection?
Isn't that only 8x8Gbit/s?
Joined: 10/20/2023(UTC) Posts: 163  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: Anders  How do you get 8x 12G-SDI on a pcie gen3 x8 lane connection?
Isn't that only 8x8Gbit/s? 8x 12G-SDI input with scaling to 3G-SDI  Capture d'ecran 2026-05-26 15374.png (226kb) downloaded 30 time(s).
 1 user thanked Kayo33 for this useful post.
Originally Posted by: DekTec America  Originally Posted by: Icerunner  Originally Posted by: DekTec America  Vmix has successfully validated multiple DekTec cards, guaranteeing seamless compatibility with minimal to zero frame drops per hour. • DTA-2178 – 8x12G-SDI/ASI Ports for PCIe • DTA-2174B – 4x 3G-SDI/ASI Ports, 1x12G for PCIe • DTA-2172 – 2x Dual 3G-SDI/ASI Ports for PCIe • DTU-351 – HD-SDI Input for USB-3 product details located at: https://www.dektec.com/selector/asisdi/Designed for 24/7 broadcast, these DekTec products are optimized for vMix software delivering high performance at a competitive price. DirectShow filters and drivers for DekTec hardware can be found at: https://www.dektec.com/downloads/SDK/#winsdkIf you need help with using DekTec card with VMIX software contact DekTec at info@dektec.com Hello! I bought DTA-2178, can i use fill/key output though this card? Hello back! Unfortunatly the DTA-2178 doesnt support fill/key at this time as this software feature has not been implemented. Could you let me know when this might be implemented, if it’s planned at all? The lack of this key feature is holding me back from making further purchases.
