thickrichard
#1 Posted : Sunday, June 23, 2024 2:07:23 AM(UTC)
thickrichard
Great to have Original Audio as an option , but echo Cancellation would be super helpful for using this in Hybrid scenarios
richardgatarski
#2 Posted : Monday, June 24, 2024 9:57:02 PM(UTC)
richardgatarski
As per https://www.vmix.com/hel...ZoomMeetingSettings.html it says (see last line):
This adjusts the audio sent from vMix to the Zoom Meetings as follows:
Reduces noise suppression
Enables stereo
Increases audio quality (via higher bitrate)
Disables echo cancellation
Note though that if you have multiple Zoom Inputs you can have different choices set for this option. That is, enable it in one Zoom Input and disable it in another Zoom Input, thus not knowing if it is enabled or not.
eee8bit
#3 Posted : Thursday, September 26, 2024 7:00:34 PM(UTC)
eee8bit
Japan
I would love to see it implemented.
I want the ZOOM participants in worship to hear praise in original sound, but echo cancellation needs to be “on” when the ZOOM participants pray.
hillel maeir
#4 Posted : Friday, January 24, 2025 4:59:32 PM(UTC)
hillel maeir
Israel
In order to use vMix as a Zoom source in hybrid conferences where the sound goes to the PA, we need to be able to play the original sound, but leave the echo cancellation on. Without this, there is no way to use vMix.
thanks 1 user thanked hillel maeir for this useful post.
eee8bit on 8/19/2025(UTC)
Eli Singer
#5 Posted : Friday, January 24, 2025 7:03:25 PM(UTC)
Eli Singer
Israel
This is very true. Please take care of it. It will greatly improve the usability of vMix in many scenarios.
thanks 1 user thanked Eli Singer for this useful post.
thickrichard
#6 Posted : Wednesday, February 26, 2025 12:57:17 PM(UTC)
thickrichard
+1
thanks 1 user thanked thickrichard for this useful post.
Eli Singer
#7 Posted : Wednesday, February 26, 2025 8:42:35 PM(UTC)
Eli Singer
Israel
+1
mlatta
#8 Posted : Tuesday, March 4, 2025 9:26:37 AM(UTC)
mlatta
Canada
+1 from me and many from the Zoom Test Kitchen community!
thanks 1 user thanked mlatta for this useful post.
eee8bit
#9 Posted : Tuesday, August 19, 2025 3:22:08 PM(UTC)
eee8bit
Japan
It's really true! Help me!
Does anyone know of any plans to implement this feature?
eee8bit
#10 Posted: : Thursday, August 21, 2025 10:31:45 PM(UTC)
eee8bit
Japan
Ideally, I would like to be able to switch echo cancellation ON/OFF while the original audio is turned ON.
If that is difficult, I would like to be able to control the original audio ON/OFF from the API.
eee8bit
#11 Posted : Thursday, November 13, 2025 7:49:19 PM(UTC)
eee8bit
Japan
Hello vMix Team,
I'm writing to request an enhancement for the Zoom integration feature in vMix.
After reviewing the vMix 29 help documentation, it appears the "Original Sound for Musicians" setting still operates the same way:
https://www.vmix.com/help29/ZoomMeetingSettings.html
Specifically, it seems we cannot enable "Original Sound" and "Echo Cancellation (EC)" at the same time.
My Feature Request:
Could you please add an option to toggle Echo Cancellation ON or OFF while Original Sound is enabled?
This functionality (EC ON + Original Sound ON) is available in the standard Zoom desktop client.
Why this is critical (Use Case): This feature is essential for scenarios like hybrid online church services.
We need to send high-quality audio (like live music) from the venue using "Original Sound." At the same time, we need to play remote participants' audio (for prayers or scripture readings) back into the venue's speakers for the local congregation to hear.
Without EC enabled, this immediately creates severe echo for the remote participants, making hybrid interaction impossible.
I am wondering if this is a limitation of the Zoom SDK. However, based on the Zoom Developer Forum, it seems controlling AEC might be possible.
This thread suggests that AEC can be managed via API calls like
Code:
stream.startAudio()
or
Code:
stream.enableBackgroundNoiseSuppression()
https://devforum.zoom.us/t/support-for-echo-cancellation/108253
It would be fantastic if the vMix team could investigate combining these API controls with
Code:
stream.enableOriginalSound()
to implement this requested feature.
Thank you for your consideration!
thanks 1 user thanked eee8bit for this useful post.
cgroom on 11/18/2025(UTC)
eee8bit
#12 Posted : Friday, November 21, 2025 11:27:51 PM(UTC)
eee8bit
Japan
Hello vMix Team,
I just checked the changelog for v29.0.0.37 and was thrilled to see this update:
* Added Original Sound and Echo Cancellation option
I wanted to send a massive THANK YOU for implementing this feature!
This is exactly what we needed. As I mentioned before, this is a game-changer for our hybrid church services. We can finally broadcast high-fidelity music ("Original Sound") while interacting with remote participants through the venue speakers without any echo issues.
Thank you so much for listening to user feedback and for your fantastic work!
Best regards,
hillel maeir on 12/23/2025(UTC)
mairginter@hotmail.com
#13 Posted : Saturday, November 22, 2025 4:17:51 AM(UTC)
Italy
Echo cancellation for guests is a big step towards simpler hybrid events!
What remains is the echo towards the stream.
For now, our only options are precise gate settings or an external DSP that performs echo cancellation using reference audio and then feeds the microphone back into Vmix.
If there were an integrated solution in VMix, I would be completely satisfied with the audio features in vmix.
hillel maeir
#14 Posted : Tuesday, December 23, 2025 8:51:05 PM(UTC)
hillel maeir
Israel
Originally Posted by: eee8bit Go to Quoted Post
Hello vMix Team,
Best regards,
Really thank you
This is really necessary and will make our work easier
