thickrichard
#1 Posted : Sunday, June 23, 2024 2:07:23 AM(UTC)
thickrichard
Great to have Original Audio as an option , but echo Cancellation would be super helpful for using this in Hybrid scenarios
richardgatarski
#2 Posted : Monday, June 24, 2024 9:57:02 PM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
As per https://www.vmix.com/hel...ZoomMeetingSettings.html it says (see last line):
This adjusts the audio sent from vMix to the Zoom Meetings as follows:
Reduces noise suppression
Enables stereo
Increases audio quality (via higher bitrate)
Disables echo cancellation
Note though that if you have multiple Zoom Inputs you can have different choices set for this option. That is, enable it in one Zoom Input and disable it in another Zoom Input, thus not knowing if it is enabled or not.
eee8bit
#3 Posted : Thursday, September 26, 2024 7:00:34 PM(UTC)
eee8bit
Japan
I would love to see it implemented.
I want the ZOOM participants in worship to hear praise in original sound, but echo cancellation needs to be “on” when the ZOOM participants pray.
hillel maeir
#4 Posted : Friday, January 24, 2025 4:59:32 PM(UTC)
hillel maeir
Israel
In order to use vMix as a Zoom source in hybrid conferences where the sound goes to the PA, we need to be able to play the original sound, but leave the echo cancellation on. Without this, there is no way to use vMix.
Eli Singer
#5 Posted : Friday, January 24, 2025 7:03:25 PM(UTC)
Eli Singer
Israel
This is very true. Please take care of it. It will greatly improve the usability of vMix in many scenarios.
thickrichard
#6 Posted : Wednesday, February 26, 2025 12:57:17 PM(UTC)
thickrichard
+1
Eli Singer
#7 Posted : Wednesday, February 26, 2025 8:42:35 PM(UTC)
Eli Singer
Israel
+1
mlatta
#8 Posted : Tuesday, March 4, 2025 9:26:37 AM(UTC)
mlatta
Canada
+1 from me and many from the Zoom Test Kitchen community!
