Ask about customizing the timeline and timecode in the video
Joined: 2/19/2025(UTC) Posts: 9  Location: Ha Noi Thanks: 6 times
Hello admin. I have 2 questions, I hope the admin can answer them for me. -Figure 1: I need to change time parameters on the video such as timecode, duration... to be able to use the video as I wish. So what should I do? , where do I need to go in Vmix to change . Figure 2: In this timeline, I cannot adjust it manually. In other words, I want to stop the timeline bar as I want on the video so I can Mark in and Mark out manually. I can only create a shortcut button to pause and play the video, but I don't know how to both pause and play back each frame. Currently I don't know where to find it in Vmix. Hope the admin can help. Thank you very much.  A&QVMIX.jpg (229kb) downloaded 2 time(s).
Originally Posted by: jaychip1001  Hello admin. I have 2 questions, I hope the admin can answer them for me.
Maybe what you need to use is instant replay
Originally Posted by: doggy  Originally Posted by: jaychip1001  Hello admin. I have 2 questions, I hope the admin can answer them for me.
Maybe what you need to use is instant replay Thanks for your answer, Doggy. I want to control this timeline bar to my liking before exiting the PGM. I am adding input in the LIST section. In this section, there are video files, including video files that I need to insert ads in the middle of the video file. I'm using the Mark in and mark out sections, but I want to adjust each frame to mark the point that needs to be marked, but I can't find a place to adjust it manually. I have to press play and then pause, which is very inconvenient. It doesn't have a jog button like some mixers. I need to jog forward and jog backward.
Originally Posted by: jaychip1001  I want to adjust each frame to mark the point that needs to be marked, but I can't find a place to adjust it manually. I have to press play and then pause, which is very inconvenient. It doesn't have a jog button like some mixers. I need to jog forward and jog backward.
Shortcuts https://forums.vmix.com/...o-advance-frame-by-frame
Originally Posted by: doggy  Originally Posted by: jaychip1001  I want to adjust each frame to mark the point that needs to be marked, but I can't find a place to adjust it manually. I have to press play and then pause, which is very inconvenient. It doesn't have a jog button like some mixers. I need to jog forward and jog backward.
Shortcuts https://forums.vmix.com/...o-advance-frame-by-frame Thank you Doggy and the admin team.
