vMix Call
Separate mono vs vst3 plugins
Joined: 3/13/2020(UTC) Posts: 38  Location: Stockholm Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
We use a vmixcall to connect two commentators to the live broadcast. We put the vmixcall input as separate mono. When we try to run wtautomixer or duganspeech, these plugins cannot handle these as separate mic inputs. If it were possible to connect a plugin to each mono separate input, it would be magical so these plugins can do their job?
@ Salleman
Please note, the “Separate Mono” feature is for sending the mono signal to both channels, not for separating the right and left channels.
Ice I know, but it would be magical if you could "handle" the left and right channels as separate mono channels that have their own handling of the vst3 plugin. It would really make things easier when you have two commentators calling in on the same vMixCall...
vMix Call
