Salleman
#1 Posted : Sunday, February 16, 2025 6:03:56 PM(UTC)
Salleman
Sweden
We use a vmixcall to connect two commentators to the live broadcast.
We put the vmixcall input as separate mono.
When we try to run wtautomixer or duganspeech, these plugins cannot handle these as separate mic inputs.
If it were possible to connect a plugin to each mono separate input, it would be magical so these plugins can do their job?
#2 Posted : Monday, February 17, 2025 12:10:30 AM(UTC)
@ Salleman
Please note, the “Separate Mono” feature is for sending the mono signal to both channels, not for separating the right and left channels.
Salleman
#3 Posted : Monday, February 17, 2025 12:21:55 AM(UTC)
Salleman
Sweden
Originally Posted by: IceStream Go to Quoted Post
@ Salleman
I know, but it would be magical if you could "handle" the left and right channels as separate mono channels that have their own handling of the vst3 plugin. It would really make things easier when you have two commentators calling in on the same vMixCall...
