Feature Requests
merge presets including their local shortcuts/activators
Joined: 6/22/2020(UTC) Posts: 14  Location: Leipzig Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Please make possible to merge two or more presets while keeping their local shortcuts and activators of both presets in the combined new preset. (For conflicts make rule: last appended preset overrides)
Background: i have some nice vmix-presets with local shortcuts and activators (MIDI Setups for different Audio Control use cases with Behringer X-Touch compact) and want to add this (MIDI) Preset to an existing vMix preset. But it will not import its shortcuts/activators. I do not want these MIDI Shortcuts and Activators to live in the global vmix config because they vary. When opening the the first Preset it will import its local shortcuts/activators but not the ones from the second Preset.
thank you very much for considering.
martin
Originally Posted by: mjehnichen  Please make possible to merge two or more presets while keeping their local shortcuts and activators of both presets in the combined new preset. (For conflicts make rule: last appended preset overrides)
martin
+1 Preset do append but not the shortcuts and/or activators i believe One can export activators but import only does a replace Shortcuts can save templates (per controller) but can be added under a different name ( maybe that can allready help a little)
thank you very much for "but can be added under a different name ( maybe that can allready help a little)"
That might help but i were not able to set a different name for activator/shortcut templates - how do you do this?
A real "merge" option would still be nice.
Originally Posted by: mjehnichen  That might help but i were not able to set a different name for activator/shortcut templates - how do you do this?
shortcut templates export and specify name to save under
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: WaltG12  +! (Scripts too!) There is a script for that ;-)
Feature Requests
