mjehnichen
#1 Posted : Thursday, February 13, 2025 9:58:29 AM(UTC)
mjehnichen
Germany
Please make possible to merge two or more presets while keeping their local shortcuts and activators of both presets in the combined new preset. (For conflicts make rule: last appended preset overrides)
Background:
i have some nice vmix-presets with local shortcuts and activators (MIDI Setups for different Audio Control use cases with Behringer X-Touch compact) and want to add this (MIDI) Preset to an existing vMix preset.
But it will not import its shortcuts/activators.
I do not want these MIDI Shortcuts and Activators to live in the global vmix config because they vary.
When opening the the first Preset it will import its local shortcuts/activators but not the ones from the second Preset.
thank you very much for considering.
martin
#2 Posted : Thursday, February 13, 2025 3:08:22 PM(UTC)
Background:
martin
+1
Preset do append but not the shortcuts and/or activators i believe
One can export activators but import only does a replace
Shortcuts can save templates (per controller) but can be added under a different name ( maybe that can allready help a little)
mjehnichen
#3 Posted : Thursday, February 13, 2025 5:04:19 PM(UTC)
mjehnichen
Germany
thank you very much for "but can be added under a different name ( maybe that can allready help a little)"
That might help but i were not able to set a different name for activator/shortcut templates - how do you do this?
A real "merge" option would still be nice.
#4 Posted : Thursday, February 13, 2025 6:56:31 PM(UTC)
shortcut templates export and specify name to save under
WaltG12
#5 Posted : Friday, February 14, 2025 1:15:51 AM(UTC)
WaltG12
+! (Scripts too!)
#6 Posted : Friday, February 14, 2025 3:18:34 AM(UTC)
Originally Posted by: WaltG12 Go to Quoted Post
+! (Scripts too!)
There is a script for that ;-)
