Feature Requests
ReplayToggleLastEventCamera1, 2, 3, 4 Activators
Add activators for when replay camera angles are selected for last event replay.
I've been advised by support there are none now. Have to watch the replay window to see what cameras are selected instead of X-Key LED lit when the camera is selected.
Thanks.
Originally Posted by: rfinley  Add activators for when replay camera angles are selected for last event replay.
Thanks. One can retrieve the selected angles with some scripting The last event is always the last one in the selected list regardless of one has reordered the events The selected list can be retrieved from the vMix API XML but will also depend if one is using A/B , A or B The Selected Angles can be retrieved ( related to the selected list, last one in that list ) from the replay2.xml file located in the currently used replay folder FYi there are also camera angles 5,6,7 and 8 possible ;-)
Joined: 7/16/2021(UTC) Posts: 3  Location: Orem, UT Was thanked: 1 time(s) in 1 post(s)
That's a bit of an awkward hack, especially considering there aren't any activators or events that fire when the selected angles change (or much else from the replay module for that matter). Or any way that I can see to change the LED status lights directly from a script.
Feature Requests
