Feature Requests
Sending Mix inputs ("Submixers") as NDI outputs
It would be very helpful if vMix could present the Mix inputs (or submixes, as I think of them) as NDI sources on our network - along with cameras /calls / audio inputs.
Joined: 4/23/2017(UTC) Posts: 1,484  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
You already have two options. Tick the checkbox to add NDI per input or use the dropdown in the output settings and set it to an input and use the 4 outputs with that.
Thanks, but if Quote:Tick the checkbox to add NDI per input is refering to the Cameras / Calls / Audio Inputs CheckBox under Additional NDI Outputs, this does not give you the Mix inputs. As for the External Outputs; yes, that works - but we are limited to only four, and I have better use for these in other areas :)
Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
Joined: 1/9/2019(UTC) Views messages in topic : 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
Joined: 7/4/2021(UTC) Posts: 428  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
First of all, once again, people need to search the forums before making/+1'ing feature request. There's no point in having a million different threads all asking for the same thing with different levels of support. Second, and more importantly, Martin explicitly said this isn't happening. Originally Posted by: admin  Hi All,
Unfortunately modern GPUs are still quite slow when it comes to downloading video back from the GPU, and this is what is needed for the vMix outputs and also to convert Mix inputs into NDI. (as all processing of outputs is done on the GPU).
This is why there are only 4 outputs in vMix, and even then they require a very fast GPU to avoid high render times when all in use.
If GPUs ever do optimise downloads a lot better, then rather than a Mix input to NDI, we would likely add the option to add as many outputs as you need and link them to any inputs you like. Much like how you can "Add Input" today.
Hope this helps.
Martin vMix
 2 users thanked WaltG12 for this useful post.
Originally Posted by: WaltG12  First of all, once again, people need to search the forums before making/+1'ing feature request. There's no point in having a million different threads all asking for the same thing with different levels of support. Second, and more importantly, Martin explicitly said this isn't happening. Originally Posted by: admin  Hi All,
Hope this helps.
Martin vMix Interesting. So if in the future Nvdia with 70x gpu cards and pci express 6.0 be more fast than now,may we have this feature. And it will be hidden in older GPU? Interesting.. I would like to see this in future how will work!
Joined: 3/21/2022(UTC) Posts: 52  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: nikosman88  Originally Posted by: WaltG12  First of all, once again, people need to search the forums before making/+1'ing feature request. There's no point in having a million different threads all asking for the same thing with different levels of support. Second, and more importantly, Martin explicitly said this isn't happening. Originally Posted by: admin  Hi All,
Hope this helps.
Martin vMix Interesting. So if in the future Nvdia with 70x gpu cards and pci express 6.0 be more fast than now,may we have this feature. And it will be hidden in older GPU? Interesting.. I would like to see this in future how will work! Hi, thanks for this quotation. However, it is two years old. Now newer PC systems have Resizable Bar support, which apparently makes the CPU->GPU transfer more efficient. For games this direction is the main one - from CPU to GPU to display. But Machine Learning / AI puts workloads on the GPU and also needs to retrieve it from there. So maybe we will see better GPU->CPU bandwidth in the future which could give vMix more Output busses. Maybe Martin can update his comment for us. Thanks, Christian
Thanks,
Christian
I don't see what there is to update. I think he was pretty clear: Originally Posted by: admin  If GPUs ever do optimise downloads a lot better, then rather than a Mix input to NDI, we would likely add the option to add as many outputs as you need and link them to any inputs you like. Much like how you can "Add Input" today. Originally Posted by: nikosman88  Interesting. So if in the future Nvdia with 70x gpu cards and pci express 6.0 be more fast than now,may we have this feature. And it will be hidden in older GPU? Interesting.. I would like to see this in future how will work!
When the time comes, I'd imagine it'd work similarly to trying to start an HEVC/AV1 stream today. You can physically click the button with any GPU, but if it's not supported, you'd get an error message that it can't do it. Or maybe it'll be like when they opened up the 4 physical outputs & they'll say "We don't really recommend doing it, but, if you want to, whatever happens is gonna happen. Do it at your own risk." I highly doubt they'll just outright hide the option based on GPU model. But when the time comes, we'll see.
Feature Requests
