MDB
#1 Posted : Saturday, February 8, 2025 2:32:42 AM(UTC)
MDB
Germany
I can set pans and crops but I would like to use the original values and calculate with them. So I miss something like GetPanX()
#2 Posted : Saturday, February 8, 2025 2:59:51 AM(UTC)
one can retrieve the current values from the vMIx API and do your calculations
Also if you just do an add or subtract value with the SetPan etc shortcuts it be from their current value
MDB
#3 Posted : Saturday, February 8, 2025 3:41:56 AM(UTC)
MDB
Germany
You could give me a hint to find it
In shortcuts I tried SetPanX as function the value ist always taken as an absolute value
vMix 4KVersion 26.0.0.47
#4 Posted : Saturday, February 8, 2025 4:05:05 AM(UTC)
some hints:
- searching this forum
- plenty of examples on how to retrieve data from the vMix API XML @ http://127.0.0.1:8088/api with scripts see "scripting for dummies" post in this forum
= mentioned numerous times in this forum on how to change values through shortcuts by adding or subtracting (example : Valu +=1 and Value -=1 etc) instead of absolute values
MDB on 2/13/2025(UTC)
MDB
#5 Posted : Monday, February 10, 2025 9:31:28 PM(UTC)
MDB
Germany
That was the syntax that I was unable to find. Thank you very much
