Joined: 7/6/2021(UTC) Posts: 22   Location: Münster Thanks: 4 times
I can set pans and crops but I would like to use the original values and calculate with them. So I miss something like GetPanX()
Joined: 12/27/2012(UTC) Posts: 5,527  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: MDB  I can set pans and crops but I would like to use the original values and calculate with them. So I miss something like GetPanX() one can retrieve the current values from the vMIx API and do your calculations Also if you just do an add or subtract value with the SetPan etc shortcuts it be from their current value
Originally Posted by: doggy  one can retrieve the current values from the vMIx API and do your calculations Also if you just do an add or subtract value with the SetPan etc shortcuts it be from their current value
You could give me a hint to find it In shortcuts I tried SetPanX as function the value ist always taken as an absolute value vMix 4KVersion 26.0.0.47
Originally Posted by: MDB  Originally Posted by: doggy  one can retrieve the current values from the vMIx API and do your calculations Also if you just do an add or subtract value with the SetPan etc shortcuts it be from their current value
You could give me a hint to find it In shortcuts I tried SetPanX as function the value ist always taken as an absolute value vMix 4KVersion 26.0.0.47 some hints: - searching this forum - plenty of examples on how to retrieve data from the vMix API XML @ http://127.0.0.1:8088/api with scripts see "scripting for dummies" post in this forum = mentioned numerous times in this forum on how to change values through shortcuts by adding or subtracting (example : Valu +=1 and Value -=1 etc) instead of absolute values
Originally Posted by: doggy  = mentioned numerous times in this forum on how to change values through shortcuts by adding or subtracting (example : Valu +=1 and Value -=1 etc) instead of absolute values
That was the syntax that I was unable to find. Thank you very much
