pagu
#1 Posted : Sunday, August 24, 2014 12:14:27 PM(UTC)
pagu
Hi dears,
How i can save jpg or png(every 1 or 2 or 5 or 10 min) file from the video in vmox or in streaming?
Thank you everyone
Al
#2 Posted : Sunday, August 24, 2014 3:34:37 PM(UTC)
a few options
- Click on the camera Icon (lower right)every ...
- create a shortcutkey with the snapshot function and use it every...
- Let an Autohotkey script trigger the shortcut Key with snapshot function every ...
- Have a VB-script (or other) do a http request for the snapshot function every ...
pagu
#3 Posted : Wednesday, August 27, 2014 6:15:46 AM(UTC)
pagu
doggy wrote:
a few options
Thank you dear doggy.
i know the function with camera icon,
how i can create the script with autokey script trigger the shortcut Key with snapshot function every 10 seconds?
any idea?
i have found one solution with http://www.videohelp.com/tools/UScreenCapture but this is not a good solution!
another way:
open another software of webcams, select vmix output and save the jpg or png, but don't want cpu overload.
Your solution is the best, i can create the batch file? you can help me?
very thanks
richardgatarski
#4 Posted : Wednesday, August 27, 2014 10:00:12 AM(UTC)
richardgatarski
I think doggy by Autohotkey script is referring to http://www.autohotkey.com/docs/commands/SetTimer.htm (or similar, never tried myself).
Unfortunately I think that this currently means that you will get a "Save as..." dialogue every time the snapshot is generated. Therefore I posted the feature request Save modifier for Snapshot shortcut. And, if I understand Martin's planning correctly, that feature (if found useful by other users) will have to wait quite a while until v15 is released.
#5 Posted : Wednesday, August 27, 2014 10:17:45 AM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
I've posted a response here:
http://forums.vmix.com.a....aspx?g=posts&t=2665
In summary: The shortcut value can be used to specify a filename
richardgatarski on 8/27/2014(UTC), doggy on 8/27/2014(UTC)
#6 Posted : Wednesday, August 27, 2014 1:18:02 PM(UTC)
Thank you Martin :-)
Pagu: using Martin's example beware to also add the time code
Autohotkey is fun to use especially when certain things are not available.
Being 'lazy' at one point for my videocoaching I manipulated videoplayback just by mouse button combinations rather than the keyboard or even the available IR remote.
Even triggerig functions/shortcuts by external switches like timing gate through the serial port :-)
doggy attached the following image(s):
