How to save jpg or png file from video or streaming
Hi dears, How i can save jpg or png(every 1 or 2 or 5 or 10 min) file from the video in vmox or in streaming? Thank you everyone Al
a few options
- Click on the camera Icon (lower right)every ... - create a shortcutkey with the snapshot function and use it every... - Let an Autohotkey script trigger the shortcut Key with snapshot function every ... - Have a VB-script (or other) do a http request for the snapshot function every ...
doggy wrote:a few options
- Click on the camera Icon (lower right)every ... - create a shortcutkey with the snapshot function and use it every... - Let an Autohotkey script trigger the shortcut Key with snapshot function every ... - Have a VB-script (or other) do a http request for the snapshot function every ... Hi, Thank you dear doggy. i know the function with camera icon, how i can create the script with autokey script trigger the shortcut Key with snapshot function every 10 seconds? any idea? i have found one solution with http://www.videohelp.com/tools/UScreenCapture but this is not a good solution! another way: open another software of webcams, select vmix output and save the jpg or png, but don't want cpu overload. Your solution is the best, i can create the batch file? you can help me? very thanks
I think doggy by Autohotkey script is referring to http://www.autohotkey.com/docs/commands/SetTimer.htm (or similar, never tried myself). Unfortunately I think that this currently means that you will get a "Save as..." dialogue every time the snapshot is generated. Therefore I posted the feature request Save modifier for Snapshot shortcut. And, if I understand Martin's planning correctly, that feature (if found useful by other users) will have to wait quite a while until v15 is released.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Thank you Martin :-) Pagu: using Martin's example beware to also add the time code Autohotkey is fun to use especially when certain things are not available. Being 'lazy' at one point for my videocoaching I manipulated videoplayback just by mouse button combinations rather than the keyboard or even the available IR remote. Even triggerig functions/shortcuts by external switches like timing gate through the serial port :-)  doggy attached the following image(s):  DF.png (49kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
