Audio sounds slowed down, and bends in pitch, pops, and sounds overall bad.
Hi everyone! I have a problem where in v-mix audio sounds slow bends in pitch, and overall bad quality. On a windows 11 machine. We did off all the enhancements. It does not matter if we use a USB soundcard, or the motherboards on board audio.
Things we did try: - check audio device settings - unable audio enhancement - setting everything to the same sample rate and tried multiple bit depths and rates. - try without sound card - updated all our drivers - uninstall the driver from the usb sound card and then try with motherboard soundcard - try audio over HDMI - ofcourse restarted the pc, and v mix multiple times - enable and disable devices in device mannager that might interfear
We did watch videos on youtube, i did search te forum but there is still no answer for us.
The problem seems to exist in v-mix only
Anyone ideas? Tnx in advance.
Fixed for the time being, by:
-setting all inputs to 60FPS instead of 59.75
Then a popping sound was still there while switching inputs, this was fixed by: Using another usb sound card instead of the berhinger umc 1820
Then a popping sound was still there while switching inputs, this was fixed by: Using another usb sound card instead of the berhinger umc 1820 Check the DC offset. Had similar popping issue with audio from a camera, fixed it using an audio plugin
