Harm VE
#1 Posted : Wednesday, February 5, 2025 4:09:05 AM(UTC)
Harm VE
Netherlands
Hi everyone! I have a problem where in v-mix audio sounds slow bends in pitch, and overall bad quality. On a windows 11 machine. We did off all the enhancements. It does not matter if we use a USB soundcard, or the motherboards on board audio.
Things we did try:
- check audio device settings
- unable audio enhancement
- setting everything to the same sample rate and tried multiple bit depths and rates.
- try without sound card
- updated all our drivers
- uninstall the driver from the usb sound card and then try with motherboard soundcard
- try audio over HDMI
- ofcourse restarted the pc, and v mix multiple times
- enable and disable devices in device mannager that might interfear
We did watch videos on youtube, i did search te forum but there is still no answer for us.
The problem seems to exist in v-mix only
Anyone ideas?
Tnx in advance.
Harm VE
#2 Posted : Wednesday, February 5, 2025 6:44:05 AM(UTC)
Harm VE
Netherlands
Fixed for the time being, by:
-setting all inputs to 60FPS instead of 59.75
Then a popping sound was still there while switching inputs, this was fixed by:
Using another usb sound card instead of the berhinger umc 1820
#3 Posted : Wednesday, February 5, 2025 2:13:13 PM(UTC)
Check the DC offset.
Had similar popping issue with audio from a camera, fixed it using an audio plugin
