Jorny
#1 Posted : Sunday, November 24, 2024 12:39:40 AM(UTC)
Jorny
Albania
I have the following problem. We use vMix and want to show a video on the speaker's laptop. The video including sound should then be streamed with vMix via Zoom. The laptop is connected via HDMI to a Birddog Mini, which we have as NDI input in vMix. The video signal is captured without any problems, but no sound is transmitted. The Birddog mini is selected as the audio output on the speaker's laptop. Does anyone have any advice on how we can solve this problem? Is there a setting in vMix that we need to adjust?
mavik
#2 Posted : Sunday, November 24, 2024 3:22:30 AM(UTC)
mavik
Why don't you use vmix call with screen share or use NDI screen capture or vMixDesktop.
I just had an important conference and people shared live coding sessions from their computer via vMixCall. This was working so beautiful. We used even wifi, no cables.
The other solutions require software install that not all presenters like or have the rights for it.
WaltG12
#3 Posted : Sunday, November 24, 2024 6:37:44 AM(UTC)
WaltG12
Can you pull up NDI Studio Monitor or OBS and see if audio is received there?
That'll give you an idea as to where in the chain your problem might be.
makrovcs
#4 Posted : Tuesday, February 4, 2025 1:28:29 AM(UTC)
makrovcs
Ukraine
In menu Birddog Mini unmute audio.
Enabling or disabling Audio
Mini can be configured to process embedded audio from
SDI or HDMI from within the web configuration console.
This setting is located in the Video section of the console
and operates in the following way:
Audio Mute ON
Audio is not passed through embedded SDI or HDMI.
Audio Mute OFF
Audio is passed through the embedded SDI or HDMI input
and streamed to the NDI receiver.
