How to Predefine and Select Telestrator Colors in vMix 28? Can It Be Set via Web API?
Joined: 1/31/2025(UTC) Posts: 4  Location: Tokyo Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
I would like to predefine multiple colors (e.g., red, blue, yellow, white) for drawing lines in the vMix 28 Telestrator and be able to select them with a single click.
Is there a way to configure this within vMix to quickly switch between predefined colors?
Additionally, is it possible to change the Telestrator line color instantly using the vMix Web API (e.g., via an HTTP request)?
Any guidance or suggestions would be greatly appreciated!
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
There are currently no shortcuts available for the telestrator. There are also no API entries, so it’s not possible to use the vMix Web API (e.g., via an HTTP request)
 1 user thanked Salvatore for this useful post.
Thank you for the clarification. That makes sense. Hopefully, shortcut support for the telestrator will be added in a future update.
