ken5o
#1 Posted : Friday, January 31, 2025 3:24:21 PM(UTC)
ken5o
Japan
I would like to predefine multiple colors (e.g., red, blue, yellow, white) for drawing lines in the vMix 28 Telestrator and be able to select them with a single click.
Is there a way to configure this within vMix to quickly switch between predefined colors?
Additionally, is it possible to change the Telestrator line color instantly using the vMix Web API (e.g., via an HTTP request)?
Any guidance or suggestions would be greatly appreciated!
Salvatore
#2 Posted : Friday, January 31, 2025 4:55:42 PM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
There are currently no shortcuts available for the telestrator. There are also no API entries, so it’s not possible to use the vMix Web API (e.g., via an HTTP request)
thanks 1 user thanked Salvatore for this useful post.
ken5o on 1/31/2025(UTC)
ken5o
#3 Posted : Friday, January 31, 2025 5:03:03 PM(UTC)
ken5o
Japan
Thank you for the clarification. That makes sense. Hopefully, shortcut support for the telestrator will be added in a future update.
