adeloche
#1 Posted : Tuesday, January 28, 2025 8:20:50 PM(UTC)
adeloche
Algeria
As an example in football in the case of offside
Key Moment Selection:
The replay operator identifies the frame where the ball is last in contact with the passer's foot.
Pause Frame:
The frame is paused for a few time at this precise moment to determine the position of attacking and defending players.
#2 Posted : Tuesday, January 28, 2025 10:34:29 PM(UTC)
Pause Frame:
I assume this to happen during actual playing of an event.
As the operator has identified the position allready he could store the position or the timecode , both available in the API XML, to be used in a script during playback that stops the play at that retrieved reference , incorporate a pause time before continuing .
Hitting the exact mark will likely depend on the playback speed chosen but there is a function to jump to that retrieved timecode as an instant tweak.
Beauty of vMix: if you want something specific to your needs , create it ;-)
adeloche
#3 Posted : Tuesday, January 28, 2025 10:55:23 PM(UTC)
adeloche
Algeria
Would you like to provide me an exemple vidéo ??
#4 Posted : Tuesday, January 28, 2025 11:07:53 PM(UTC)
of what?
adeloche
#5 Posted : Tuesday, January 28, 2025 11:10:06 PM(UTC)
adeloche
Algeria
of what?
Instant Replay with pause point frame
When play the event it pause automaticaly for 2 sec
And countinue Again
nikosman88
#6 Posted : Tuesday, January 28, 2025 11:28:19 PM(UTC)
nikosman88
Greece
You can use a simple script like
Code:
API.Function("ReplayPause", Channel:="1")
sleep (2000)
API.Function("ReplayPlay", Channel:="1")
#7 Posted : Wednesday, January 29, 2025 12:08:55 AM(UTC)
of what?
And countinue Again
You really need to be cleare on your request.
want an operator to set the footage at a specific frame , show it at auto play further after certain time
or
operator specifies a certain pause point , the replay footage (event) is played from beginning , pauses at reference point and then continues after cettain pause time .
be it for a feature request or a solution in general it helps a lot if its clearly explained to avoid waisting time getting a possible result
and no , have no video of it of a at the moment of a theoretical request , maybe you can make one to show exaclty what you want the end result to be
