Feature Requests
Instant Replay Pause Frame
As an example in football in the case of offside Key Moment Selection: The replay operator identifies the frame where the ball is last in contact with the passer's foot. Pause Frame: The frame is paused for a few time at this precise moment to determine the position of attacking and defending players.
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: adeloche  As an example in football in the case of offside Key Moment Selection: The replay operator identifies the frame where the ball is last in contact with the passer's foot. Pause Frame: The frame is paused for a few time at this precise moment to determine the position of attacking and defending players.
I assume this to happen during actual playing of an event. As the operator has identified the position allready he could store the position or the timecode , both available in the API XML, to be used in a script during playback that stops the play at that retrieved reference , incorporate a pause time before continuing . Hitting the exact mark will likely depend on the playback speed chosen but there is a function to jump to that retrieved timecode as an instant tweak. Beauty of vMix: if you want something specific to your needs , create it ;-)
Would you like to provide me an exemple vidéo ??
Originally Posted by: adeloche  Would you like to provide me an exemple vidéo ?? of what?
Originally Posted by: doggy  Originally Posted by: adeloche  Would you like to provide me an exemple vidéo ?? of what? Instant Replay with pause point frame When play the event it pause automaticaly for 2 sec And countinue Again
You can use a simple script like Code:
API.Function("ReplayPause", Channel:="1")
sleep (2000)
API.Function("ReplayPlay", Channel:="1")
Originally Posted by: adeloche  Originally Posted by: doggy  Originally Posted by: adeloche  Would you like to provide me an exemple vidéo ?? of what? Instant Replay with pause point frame When play the event it pause automaticaly for 2 sec And countinue Again You really need to be cleare on your request. want an operator to set the footage at a specific frame , show it at auto play further after certain time or operator specifies a certain pause point , the replay footage (event) is played from beginning , pauses at reference point and then continues after cettain pause time . be it for a feature request or a solution in general it helps a lot if its clearly explained to avoid waisting time getting a possible result and no , have no video of it of a at the moment of a theoretical request , maybe you can make one to show exaclty what you want the end result to be
Feature Requests
