mark
#1 Posted : Monday, January 20, 2025 9:35:51 PM(UTC)
mark
To set the stage I have followed the setup here.
https://www.vmix.com/kno...2/using-srt-urls-in-vmix
Paraphrased
SRT URLs commonly look like the following:
srt://1.2.3.4:10000/?mode=caller&passphrase=thepassword
These should be separated out to fill in the fields in vMix:
Hostname: Just the IP address or hostname, for example 1.2.3.4 as per the example above. Do not include srt:// the port or any other values.
Port: This is the number after the hostname. In the above example 10000
Type: Caller in the example above, also called "mode"
Passphrase: thepassword as per the example above
I am trying to get a SRT stream to work in Vmix - string below
srt://live.cloudflare.com:778?passphrase=bb9ce8d40eee58867827c3554f584ed2kf366fc71fb65806db058177696b634f1&streamid=playf366fc71fb65806db058177696b634f1
This works fine if I open Network URL in VLC and paste it as is, but does not work in Vmix
I have tried using caller and rendezvous with each field in its separate spot.
So that is as per instructions to leave out the srt:// in the string so assuming it is the same for the rest eg passphrase and streamid so that leaves
srt
live.cloudflare.com
port
778
passphrase
streamid
I have tried it with passphrase and stream id both in the field and not in the field
All I get is black screen in vmix
Anyone have a clue as to what I must be doing wrong?
elvis55
#2 Posted : Monday, January 20, 2025 10:07:20 PM(UTC)
elvis55
Switzerland
vMix Tutorials- Using SRT for input and output of video using regular internet!
mark
#3 Posted : Monday, January 20, 2025 11:24:00 PM(UTC)
mark
Thanks for that video. I am aware of this and had already tested this using this actual video. Though it will be good for anyone reading this post. who is learning SRT
I am already able to do a SRT stream to myself locally no problem. as per video.
I am also able to do from one computer to another on same network.
Just not the stream documented above that does work fine on VLC as a single string
So are there any other settings not documented that I might have missed.
EG do you include the word "passphrase" in the actual field for input for passphrase or leave it out?
Same for Stream ID ?
EG does Vmix transmit the entire string with passphrase on the front?
Clearly Vmix adds SRT:// to the front of the URL for hostname internally. and transmits this as it will not even allow you to add SRT;?? to the front of the hostname.
So what I am asking is why is this string not working due to some oversight by me?
Peter1000
#4 Posted : Tuesday, January 21, 2025 12:29:15 AM(UTC)
Peter1000
Switzerland
Was thanked: 85 time(s) in 65 post(s)
#5 Posted : Wednesday, January 22, 2025 1:01:24 PM(UTC)
It looks like you have accidentally included the & symbol in the passphrase you have copied.
Note that vMix is not converting all the fields back into srt:// etc, it is actually the opposite.
SRT requires all these fields set separately internally, some apps just use the srt:// URL format for convenience.
mark on 1/23/2025(UTC)
mark
#6 Posted : Thursday, January 23, 2025 11:51:23 AM(UTC)
mark
Thanks Admin,
Did not spot that & symbol, literally thought it was part of the passphrase.
Figured it had to be a syntax thing that was catching me out.
Hopefully this will help the next person that hits this URL format that is all in one string.
Look for the rogue & symbol!
