amaldonado31
#1 Posted : Sunday, January 19, 2025 6:02:15 AM(UTC)
amaldonado31
Hi, this is a very basic question, but I can't seem to find the answer on the forums.
I have several playlists that I would like to create shortcuts to in order to be able to manage from my ipad using the webcontroller. When I try to set up the shortcut, this is what I enter:
Key/Control: A
Function: SelectPlayList
Value: pregame (this is the name of one of my playlists)
Title: play pre
Display: Default
Show in Web Controller: checked off
When I have one playlist playing (say, Sponsors), i want to be able to select this shortcut so that it switches over to my pregame playlist. When I select this shortcut, however, nothing happens and the Sponsors playlist continues to play.
I feel like I am missing something very simple or obvious, but the only thing that the Vmix User guide has under Shortcut Function Reference is:
SelectPlayList:
Open PlayList with Name matching Value
Value = PlayList
Any help would be greatly appreciated. Thanks!
thanks 1 user thanked amaldonado31 for this useful post.
angelson on 1/26/2025(UTC)
#2 Posted : Sunday, January 19, 2025 7:36:29 AM(UTC)
Key/Control: A
Title: play pre
Display: Default
SelectPlayList:
Value = PlayList
Try with adding the shortcut for first "stopplaylist" the current playlist (can combine it under the same key) followed by a startplaylist after other list is selected
amaldonado31
#3 Posted : Sunday, January 26, 2025 5:35:05 AM(UTC)
amaldonado31
Thank you! It worked by adding:
Stop playlist
Select playlist
Start playlist
Thanks for your help!
