Joined: 1/19/2025(UTC) Posts: 2  Was thanked: 1 time(s) in 1 post(s)
Hi, this is a very basic question, but I can't seem to find the answer on the forums.
I have several playlists that I would like to create shortcuts to in order to be able to manage from my ipad using the webcontroller. When I try to set up the shortcut, this is what I enter:
Key/Control: A Function: SelectPlayList Value: pregame (this is the name of one of my playlists) Title: play pre Display: Default
Show in Web Controller: checked off
When I have one playlist playing (say, Sponsors), i want to be able to select this shortcut so that it switches over to my pregame playlist. When I select this shortcut, however, nothing happens and the Sponsors playlist continues to play.
I feel like I am missing something very simple or obvious, but the only thing that the Vmix User guide has under Shortcut Function Reference is:
SelectPlayList:
Open PlayList with Name matching Value
Value = PlayList
Any help would be greatly appreciated. Thanks!
 1 user thanked amaldonado31 for this useful post.
Joined: 12/27/2012(UTC) Views messages in topic : 5,537  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: amaldonado31  Hi, this is a very basic question, but I can't seem to find the answer on the forums.
SelectPlayList:
Value = PlayList
Any help would be greatly appreciated. Thanks! Try with adding the shortcut for first "stopplaylist" the current playlist (can combine it under the same key) followed by a startplaylist after other list is selected
Thank you! It worked by adding:
Stop playlist
Select playlist
Start playlist
Thanks for your help!
