TJBoud
#1 Posted : Sunday, January 5, 2025 12:31:26 PM(UTC)
TJBoud
Views messages in topic : 1
I have an Osmo Action 4 camera trying to import as webcam. I select webcam on Osmo and it connects in vMix HD 27.0.0.88 x64 as a camera source.
However, moving subjects stutter on screen. Any idea how to fix?
jahumphr
#2 Posted : Saturday, April 26, 2025 3:52:55 AM(UTC)
jahumphr
I have the same problem with Osmo Action 5, it works fine in OBS. Any ideas?
zenvideo
#3 Posted : Saturday, April 26, 2025 4:46:17 AM(UTC)
zenvideo
Could it be the encoding "Video Format" that you're trying to use? The Default is typically trying to use uncompressed video, which may result in a much reduced framerate from a webcam. Try selecting "MJPG" from the bottom of the list of formats and see if it's any better.
fcvideo on 4/8/2026(UTC)
fcvideo
#4 Posted : Wednesday, April 8, 2026 6:56:51 PM(UTC)
fcvideo
I have the same problem with Osmo Pocket 3 - and changing the format to MJPG worked a treat, thanks for this
