3rd Party Software and Development
Scripting .net - Get button / Joystick / Midi values?
Is there anyway that you can listen what buttons are pressed or what shortcuts are pressed / used. And get the value of the midi slider / joystick?
Thanks: 1 times Was thanked: 5 time(s) in 4 post(s)
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: Tuomas  Is there anyway that you can listen what buttons are pressed or what shortcuts are pressed / used. And get the value of the midi slider / joystick?
Thanks, but that video talks about MIDI only and there is no scripting in it.
I've actually came up with a solution - AutoHotkey (Win only). Here is a function I've found on the internet for sending commands to vMix via the web api. Here it is adjusted for AHK2 + some usage Code:URL2Var(URL) { ; This delivers the URL over the web to vMix
WebRequest := ComObject("WinHttp.WinHttpRequest.5.1")
WebRequest.Open("GET", URL)
WebRequest.Send()
Return WebRequest.ResponseText()
ControllerNumber := 1 ;joystick ID
frameRate := 29.97
Loop
;get x axis and normalize to <-1..1>
x := Round((GetKeyState(ControllerNumber "JoyX")-50)/50, 10)
;write joystick value into DynamicValue in vMix
URL2Var("http://127.0.0.1:8088/api/?Function=SetDynamicValue1&Value=" . x)
;perform once per frame
Sleep 1000/frameRate
Originally Posted by: Brano  Thanks, but that video talks about MIDI only and there is no scripting in it. is what OP asked, not you ;-)
