Tuomas
#1 Posted : Friday, January 6, 2023 8:55:29 PM(UTC)
Tuomas
Finland
Is there anyway that you can listen what buttons are pressed or what shortcuts are pressed / used. And get the value of the midi slider / joystick?
Brano
#2 Posted : Monday, December 30, 2024 12:29:10 AM(UTC)
Brano
+1 for any idea
#3 Posted : Monday, December 30, 2024 2:39:20 AM(UTC)
Brano
#4 Posted : Thursday, January 2, 2025 5:05:28 AM(UTC)
Brano
Thanks, but that video talks about MIDI only and there is no scripting in it.
Brano
#5 Posted : Thursday, January 2, 2025 5:09:05 AM(UTC)
Brano
I've actually came up with a solution - AutoHotkey (Win only).
Here is a function I've found on the internet for sending commands to vMix via the web api. Here it is adjusted for AHK2 + some usage
Code:
URL2Var(URL) { ; This delivers the URL over the web to vMix
	WebRequest := ComObject("WinHttp.WinHttpRequest.5.1")
	WebRequest.Open("GET", URL)
	WebRequest.Send()
	Return WebRequest.ResponseText()
ControllerNumber := 1 ;joystick ID
frameRate := 29.97
Loop
	;get x axis and normalize to <-1..1>
	x := Round((GetKeyState(ControllerNumber "JoyX")-50)/50, 10)
	;write joystick value into DynamicValue in vMix
	URL2Var("http://127.0.0.1:8088/api/?Function=SetDynamicValue1&Value=" . x)
	;perform once per frame
    Sleep 1000/frameRate
#6 Posted : Thursday, January 2, 2025 7:02:39 AM(UTC)
is what OP asked, not you ;-)
