fabfab10
#1 Posted : 4 months ago
fabfab10
Italy
i was wondering if there is a way to check if an image or a text is visible in a graphic overlay using API.
I can turn them ON or OFF using SetTextVisible or SetImageVisible , any way to check the current state?
#2 Posted : 4 months ago
Was thanked: 989 time(s) in 821 post(s)
Originally Posted by: fabfab10 Go to Quoted Post
No
But you could keep track of it yourself when using the visibility on/off functions (w script)
fabfab10
#3 Posted : 4 months ago
fabfab10
Italy
No
You mean by using a variable where manually store the status, and than checking against this variable?
#4 Posted : 4 months ago
No
Yes. Use dynamicvariables for example
