API - Function for status checkin
Joined: 2/20/2019(UTC) Posts: 68  Location: Firenze Was thanked: 5 time(s) in 5 post(s)
Hello, i was wondering if there is a way to check if an image or a text is visible in a graphic overlay using API. I can turn them ON or OFF using SetTextVisible or SetImageVisible , any way to check the current state?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: fabfab10  Hello, i was wondering if there is a way to check if an image or a text is visible in a graphic overlay using API. I can turn them ON or OFF using SetTextVisible or SetImageVisible , any way to check the current state? No But you could keep track of it yourself when using the visibility on/off functions (w script)
Originally Posted by: doggy  Originally Posted by: fabfab10  Hello, i was wondering if there is a way to check if an image or a text is visible in a graphic overlay using API. I can turn them ON or OFF using SetTextVisible or SetImageVisible , any way to check the current state? No But you could keep track of it yourself when using the visibility on/off functions (w script) You mean by using a variable where manually store the status, and than checking against this variable?
Originally Posted by: fabfab10  Originally Posted by: doggy  Originally Posted by: fabfab10  Hello, i was wondering if there is a way to check if an image or a text is visible in a graphic overlay using API. I can turn them ON or OFF using SetTextVisible or SetImageVisible , any way to check the current state? No But you could keep track of it yourself when using the visibility on/off functions (w script) You mean by using a variable where manually store the status, and than checking against this variable? Yes. Use dynamicvariables for example
