dbonser
#1 Posted : Friday, December 27, 2024 8:55:03 AM(UTC)
dbonser
We have Vmix on a computer and are projecting to another monitor and the screen. There has been a change in functionality in the last 2 months. If we run Vmix fullscreen on the computer monitor, about half way through our church service it will resize itself to half the size. Then it will display a message asking if we want to save changes as if we had tried to close it. It also automatically pops up the audio setting while playing a video.
Is there a setting I need to change?
Deb
#2 Posted : Friday, December 27, 2024 9:11:14 AM(UTC)
Deb
Thats some high powers at work ;-)
define halfway , is this at a defined time after starting vamix, starting the computer ...
Audio settings , windows or vMix one ?
Did someone "work" on the system some 2 months ago ?
Any scripts in the vMix setup or the system ?
dbonser
#3 Posted : Friday, December 27, 2024 12:17:42 PM(UTC)
dbonser
Let me share our process.
We play 3 videos at the beginning of the service, do a prayer, then another video, then a powerpoint sermon.
It happens at either the 2nd or 3rd video (not always the same), but once it happens it continues happening about every 15 minutes.
I am recording the sermon, but at the point this happens I am not recording and no there is no scripts. We are very simple. :) At least I thought so.
jet
#4 Posted : Friday, December 27, 2024 9:40:56 PM(UTC)
jet
Was thanked: 23 time(s) in 21 post(s)
Deb
What version of vMix is used?
What Os?
Hardware specs?
dbonser
#5 Posted : Saturday, December 28, 2024 12:22:18 AM(UTC)
dbonser
Version 48.0.59.94 and we are using it on Windows 10. We can't upgrade to Version 11 and I don't want to.
#6 Posted : Saturday, December 28, 2024 12:24:18 AM(UTC)
Version 48.0.59.94
Really spooky now, so far into the future
dbonser
#7 Posted : Saturday, December 28, 2024 12:25:21 AM(UTC)
dbonser
Windows 10 Pro
8 GB RAM
1 TB drive, with 511 GB Free
dbonser
#8 Posted : Saturday, December 28, 2024 12:34:11 AM(UTC)
dbonser
Maybe the version was wrong. The build is 48059.94.
Version is 27.0.0.89 v64
elvis55
#9 Posted : Saturday, December 28, 2024 2:00:15 AM(UTC)
elvis55
Switzerland
How is the setup, connection to the monitor and to the screen? With HDMI or SDI? Maybe a sketch.
dbonser
#10 Posted : Saturday, December 28, 2024 3:36:07 AM(UTC)
dbonser
Not sure how the hookup to the projector/screen would affect this, the resizing only happens to the monitor connected to the computer, but I'll try to explain. I'm not good at sketching.
Computer is under desk and monitor is connected to the desktop with HDMI cable and then another HDMI connects to second monitor. HDMI cable runs up through ceiling to the projector which sends signal to the projector screen.
The thing is that it worked correctly up until 2 updates ago. And the wiring has not changed since then.
jet
#11 Posted : Friday, January 3, 2025 11:13:26 PM(UTC)
jet
Can you revert to an older version of vMix and see if the issue will go away? If the issue persists with older releases then it is unlikely vMix fault and vice versa.
rjwerth
#12 Posted : Sunday, July 20, 2025 11:26:35 PM(UTC)
rjwerth
Sounds to me like a rogue or faulty input device such as a keyboard, touch screen, etc.
Robert
dbonser
#13 Posted : Sunday, July 20, 2025 11:40:56 PM(UTC)
dbonser
After much troubleshooting and reinstalling windows and vmix and other things, it turned out that it was a bad usb port. We had a touch screen monitor which was plugged into the USB port. We unplugged that (we never use the touch feature anyway) and everything has been working fine. Thank you to all that reached out to try to help us.
Guest (5)
