HEVC stream encoding error "No capable devices found"
Joined: 10/30/2023(UTC) Posts: 39  Location: Hull Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
Hi, trying to set up a stream with HEVC encoding. The laptop has GTX1650 which should be capable of HEVC encoding. I get 2 error messages - "[hevc_nvenc @ 0000021a41b844c0] B frames as references are not supported" "[hevc_nvenc @ 0000021a41b844c0] No capable devices found"
Does anyone know what is going wrong here?
Ah ... I looked at that table but I did not see that there was more of it if I scrolled to the right.
Can VMix stream HEVC without using b-frames? It appears to be an option in FFMPEG but I can't see how you would configure it in VMix.
Originally Posted by: congoblue  Can VMix stream HEVC without using b-frames? It appears to be an option in FFMPEG but I can't see how you would configure it in VMix. Nope , but one can use ffmpeg to encode a vMix external with b frames tweak and stream it If its worth it is another question
