3rd Party Software and Development
LIVE Interpretation translation to subtitles
Hello all,
We need a real solution for events and seminars.
We need all the seminars should be live translated with subtitles (no voice translation), therefore I ask you guys if there is any solution using vMIX.
There is any way to use the vMIX scripts or something to use in conjunction with speech to text program to embedded on a live streaming, maybe as a source?
There are many solutions that can translate speech to text, but the main problem is how can I config vMIX so it can read line by line the text and transform it as a source.
Thank you very much with your feedback.
Hello all,
We need all the seminars to be live translated with subtitles (no voice translation), therefore I ask you guys if there is any solution using vMIX.
Is there any way to use the vMIX scripts or something to use in conjunction with a speech-to-text program to embed it in a live stream, maybe as a source?
There are many solutions that can translate speech to text, but the main problem is how can I configure vMIX so it can read line by line the text and transform it as a source.
Thank you very much for your feedback.
I know this reply might be a bit late, but it seems that there are now many solutions available to handle this kind of problem, and the process is usually 1. First, convert the sound into text by recognizing the audio track. 2. Convert the text into the desired language using AI technology. If the requirement is really for a real-time solution, the cost seems a bit high, but if it is a pre-recorded video or a video with some time delay, this implementation doesn't seem too difficult. Many tools provide similar services, such as subtitle translator, or you can also use Google Translator, but Google's service is always somewhat unsatisfactory.
I'm not sure if this answers your question (I may be misunderstanding what you're looking for) - but at my church we used to use webcaptioner (which has now been discontinued) to do what I TINK you're asking. We translated two languages as our pastor preached, Arabic and Spanish. We had a human translator for each. The translator sat a computer (these were cheap laptops) and translated the sermon real time into Webcaptioner. This produced an "on screen" text on their computer. That text was then sent to vMix via NDI, and an alpha channel set so the text was an overlay. I then position both translations in "out of the way" places so the pastor could be seen.
