vjmandala
#1 Posted : Thursday, November 21, 2024 3:38:36 PM(UTC)
vjmandala
Hi all, for an unknown reason some/all of the Vmix clips and prev/pgm monitors go blank at random times soon after I load preset.
After rebooting or quit/relaunch VMix it comes good, then if I go into vmix settings, a clip settings or just wait a min, some/all monitors go blank again.
This is using a (work) Surface Pro 4 laptop with 8gb mem. Has been working perfectly fine for a couple years.
Vmix display at Pal 25fps 1080p. High Performance mode checked or uncheck makes no dif. VMix shows CPU 3% GPU 2%.
Any ideas would be most helpful.
The Good
The Bad
The Ugly
#2 Posted : Thursday, November 21, 2024 8:48:41 PM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
This is typically due to some corrupt files in your vMix installation.
This usually happens as a result of dismissing/ignoring the warning message during a vMix update or install about a file it can't install.
If this happens, restart the computer, make sure absolutely all programs and browsers are closed, then install vMix again.
vjmandala
#3 Posted : Sunday, November 24, 2024 5:09:35 AM(UTC)
vjmandala
Makes total sense. As my laptop belong to Uni, the install (update) was blocked part way through. Am waiting for IT to give me (VMix) permission to update s/w. Thank you for confirming this would be the cause 🙏🏼
** Re-Update worked - issue fixed, thanks **
