LG
#1 Posted : Monday, August 18, 2014 5:47:26 AM(UTC)
LG
Vmix 13 = min windows 7 directx 10
Vmix 12 = min windows 7 ( partial XP support ) directx 10
Vmix 11 = min windows XP directx 9
can anyone finish this list?
when did Vmix stop supporting windows XP and what DirectX is the min for that version?
i am asking this because i also have a older system and would like to use some basic stuff of the older vmix
but have no cleu what latets version still works on windows XP and with what directx version ( my xp is directx 8 or 9 )
ceejay7777
#2 Posted : Monday, August 18, 2014 10:33:22 PM(UTC)
ceejay7777
Based on discussions in this thread, I've stuck with 11.0.0.63 on my XP box, running DirectX 9.0c.
#3 Posted : Tuesday, August 19, 2014 4:50:16 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
11.0.0.66 is the latest from version 11, .63 is NOT recommended.
With all versions, XP is no longer officially supported as Microsoft has stoppped support also.
Also, we no longer have any XP systems available for testing.
If it works for you, then by all means use it, but we can't provide support or fixes if something goes wrong.
LG
#4 Posted : Tuesday, August 19, 2014 8:59:14 AM(UTC)
LG
11 66 ok
and where do i still download this version?
#5 Posted : Tuesday, August 19, 2014 9:29:50 AM(UTC)
LG
#6 Posted : Tuesday, August 19, 2014 9:45:35 AM(UTC)
LG
thx!
is this version only from dirext9 and up or also 8 and what version did work with directx 8? or was there no version with that.
LG
#7 Posted : Tuesday, August 19, 2014 12:08:52 PM(UTC)
LG
edit
no luck the csard is directx 8 only i geuss there is no version of vmix that goes below directx9?
wwdv
#8 Posted : Tuesday, August 19, 2014 5:39:54 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
VMix 12 is working OK with WinXP (directX9)
However there are some features that are not working in XP:
-streaming (you can use FMLE standalone)
-mp4 recording
-there is no virtual vMix audio output device in WinXP
ceejay7777
#9 Posted : Tuesday, August 19, 2014 8:47:31 PM(UTC)
ceejay7777
With all due respect, I'm using .63 specifically because of a problem that was pointed out with .66 and XP in the thread I posted:
wwdv wrote:
I updated to 11.0.0.66 (uninstalled old version first) and got an error when starting vMix:
Can not find entrypoint from procedure CreateEventExW in DLL-file KERNEL32.dll
(OS is WindowsXP SP3)
admin wrote:
This error is due to a component of vMix that requires Windows Vista or higher.
vMix will still run after you click ok, however you will need to upgrade to Windows 7 or 8
as XP is reaching end of life and will no longer be supported
