AJA Io 4k Plus - what ports that vMix can use?
Hi, I have a AJA IO 4K Plus and have it mostly working with my Thunderbolt laptop with vMix 27 I can see the 4 x SDI input ports fine and can also see 5 ports for outputs. I can only select 1 to 4 SDI,s as either in or out (out via external).
Questions
1) The 4K plus has a HDMI IN and OUT ports so can I use them as another input and output? 2) The SDI Monitor port does not seam to be selectable as a output - is this correct? 3) The Analog Audio IN/OUT (4 in and 4 out) how do you select them as a audio input on vMix
thanks
Paul
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
NO, it is an alternative....if you use the HDMI, you lose an SDI in/out...READ the manual...if you do not have one, go download it from AJA site......I use similar so I know...I have the older version....
