Paul CVP
#1 Posted : Wednesday, November 6, 2024 9:50:28 AM(UTC)
Paul CVP
New Zealand
I have a AJA IO 4K Plus and have it mostly working with my Thunderbolt laptop with vMix 27
I can see the 4 x SDI input ports fine and can also see 5 ports for outputs. I can only select 1 to 4 SDI,s as either in or out (out via external).
Questions
1) The 4K plus has a HDMI IN and OUT ports so can I use them as another input and output?
2) The SDI Monitor port does not seam to be selectable as a output - is this correct?
3) The Analog Audio IN/OUT (4 in and 4 out) how do you select them as a audio input on vMix
thanks
Paul
Luis70
#2 Posted : Wednesday, November 6, 2024 4:42:17 PM(UTC)
Luis70
Grenada
NO, it is an alternative....if you use the HDMI, you lose an SDI in/out...READ the manual...if you do not have one, go download it from AJA site......I use similar so I know...I have the older version....
