Feature Requests
UI Overhaul to Honor Input Keys
Joined: 9/7/2024(UTC) Posts: 60  Location: The Great PNW Was thanked: 10 time(s) in 9 post(s)
Various elements within the interface do not honor their assigned Input Key and instead only reference the input number. One HUGE example of this oversight is in the Settings / Shortcuts or Activators. If you reorder anything within any run of controls or feedbacks your entire configuration requires a detailed repair and validation. This can take hours if you have a large show with multiple points of contact. Other areas include Layer selection, Multiview Layout assignments, and others.
ALL INTERFACE ELEMENTS should be locked to what you have selected unless they are removed to which they simply become blank. If you don't have control over specifying what version of an input ID it should be using, ie: Name/#/ID, it should DEFAULT to the UNIQUE ID.
This has to be one of the worst and most frustrating developer errors in vMix!!!
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: offroadmediagroup  ... oversight is in the Settings / Shortcuts or Activators. Tick the "Assign Activator to Input Number" box if you want this activator assigned to a particular input position only, so if inputs are moved around in vMix, the activator will not move. https://www.vmix.com/help27/ActivatorsEdit.html
Originally Posted by: dmwkr  Originally Posted by: offroadmediagroup  ... oversight is in the Settings / Shortcuts or Activators. Tick the "Assign Activator to Input Number" box if you want this activator assigned to a particular input position only, so if inputs are moved around in vMix, the activator will not move. https://www.vmix.com/help27/ActivatorsEdit.html It's actually the opposite. I want it to respect the Unique ID of the Input selected... which is not currently honored. If I set volume faders, for example, to Inputs 1-8, then add a 9th input and move it to position 1 or 5 or what ever, that stack of assignments breaks.
I just quoted the help files. In your case it should behave like you want it to if you untick the checkbox.
Originally Posted by: dmwkr  I just quoted the help files. In your case it should behave like you want it to if you untick the checkbox. Right... but it doesn't. Nor do many other places within vMix as mentioned in the original post. I can't imagine this is a "bug" as it's not one place only.
Feature Requests
